Thread: What is this and how can I get rid of it?
    dtrujillo63's Avatar
    Feb 2015
    Los Angeles
    33
    Can someone help identify the white spots/streaks in my pool and how I can go about removing them? The pool is only a year old and I do a pretty good job at keeping everything balanced. The two issues I do have is PH always raising (I have to add acid every other day) and the fact that I have really hard water. I've never had algae in my pool and the only two products I ever use is liquid chlorine and muriatic acid.
    FC: 5.0
    CC: 0.0
    PH: 7.6
    TA: 100
    CH: 700
    CYA: 50
    30 x 20 IG Play Pool + 7' Spa ~16K Gallons, French Gray Plaster, Pentair Intelliflow VS, Pentair CCP420, Pentair MasterTemp 400K Heater, Intellibrite LEDs.
    Mod Squad mknauss's Avatar
    May 2014
    Laughlin, NV
    5,381
    Re: What is this and how can I get rid of it?
    Looks like scale. Put your data into PoolMath. Your CSI is positive -- and with an elevated CH you need to keep it between zero and -0.3.
    Probably too late now. Most likely will need to be drained and soda blasted to remove.
    6000 Gallon IG Fiberglass with integrated Spa
    Pentair CCP240 Cartridge Filter with Pentair Intelliflo 3050VS Pump and Pentair HTR250 heater. IC40 SWG. EasyTouch 4. TF 100 Test Kit w/SpeedStir!
    CLICK HERE to Become a TroubleFreePool.com Supporter!!
    Marty
    Jun 2010
    Glendale, CA
    513
    How are you adding the acid to the pool?
    I accidentally created some white patches in my grey plaster slowly adding straight acid in front of the return.
    For some reason I can't see these pics to confirm....
    16K Gal Plaster | Compupool SWG | Intelliflow VF | TF-100
    Mod Squad pooldv's Avatar
    DFW, TX
    24,493
    Yeah, I can't see pics either. Upload them to Photobucket, copy the IMG code next to the pic and paste it in your post. That will embed the pic in your thread.
    If it is scale, as MK suggested you can mailntain CSI at -0.3 to 0 to prevent scale. You can lower CSI to -0.8 to -0.9 and brush a lot to see if it will start to dissolve over time. It will take a while, about as long as it took the scale to build up. If the plaster is a year old you can use a stainless steel brush for more aggressive brushing.
    More here, Pool School - Calcium Scaling
    You can also do a no drain acid bath, which is more aggressive than above but less aggressive than draining and blasting of acid washing.
    More here, The Zero Alkalinity Acid Treatment
    Feb 2015
    Los Angeles
    33
    I just re-uploaded the pictures. I add acid by walking around the pool. Since I have such hard water, should I try to keep my pH level on the low side? I'm usually around 7.8 and I can't seem to keep it down for more than a day without adding acid.
    30,421
    Your pH should never be above 7.8 and with that very high CH, I would keep it at 7.4.....regardless of how much acid it took.
    The cause of your scale is high pH, high CH, and high TA
    Walking around the pool pouring acid is not the best. Lower the acid jug almost into the water and pour it SLOWLY in front of a return - pump running.
