Thread: Cyanuric Acid and Swimming?
    Jul 2016
    Saskatchewan
    6
    I just put in stabilizer in a sock by my return line yesterday afternoon. Over half of the stabilizer is dissolved. Am I able to swim in the pool with the stabilizer still dissolving in the sock?
    Intex 16' Above Ground Pool 3800 gallons
    Krystal Clear Cartdridge Filter Pump 1,000 gph flow rate
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Cyanuric Acid and Swimming?
    As long as the pool is "safe" then yes.
    What is safe?
    -FC is below shock level
    -Water is clear enough so you can see the bottom in the entire pool
    CYA dissolving in a sock should not stop swimming.
    Support the site
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    I usually give the sock some extra squeezing when I am in the pool.
