Results 1 to 10 of 10
Thread: Closing soon
    dm9287's Avatar
    Jul 2016
    Webb City Missouri
    5
    Closing soon
    We are going to be new pool owners in about two weeks and look forward to learning a lot from this group.
    domct203's Avatar
    Jun 2015
    CT
    3,592
    Re: Closing soon
    Welcome!
    Will this be your first pool ownership?
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Closing soon
    Welcome to TFP and congrats on the new pool!
    dm9287's Avatar
    Jul 2016
    Webb City Missouri
    5
    Re: Closing soon
    Yes it is going to be our first pool. 1632 kidney shaped pool 8 feet deep according to the owners it's supposed to be 16000 gallons.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Closing soon
    Welcome to TFP dm9287
    As you get more info on your pool please take the time to add it to your signature as outlined here: Pool School - Getting Started
    Now would be a great time to find out if the present owner did their own maintenance/testing of the water and if they have a good kit. You need to have a good test kit and not one of the cheap ones from a big box store or Walmart. Now is the time to get one ordered. TF100 TFTestkits.net
    You should also find out what they have been using as a sanitizer so you have a clue to what you're walking into. If they have been using most of the box store or pool store products you might end up having to replace a lot of water shortly after taking over because of a high CYA concentration.
    BUT . . . relax it's only water and the new house is really the focus !! Congratulations.
    Solar Blanket, Well Water, Borax Added. 68
    dm9287's Avatar
    Jul 2016
    Webb City Missouri
    5
    Re: Closing soon
    Thanks for the information
    Inground 16x32 Kidney shaped plaster pool 16,000 Gallons
    1.5 HP Pentair Superflo VS Pump
    Pentair Sand Filter
    dm9287's Avatar
    Jul 2016
    Webb City Missouri
    5
    Re: Closing soon
    (Taylor K-2006C vs. Taylor K-2006 vs. TF100)
    I believe the pool has been maintained by pool store advice but I believe we would rather use the bbb. With that said I have seen all three of these test kits talked about. What is best and do we need any other tests I am also wanting to put some salt in the system just for water feel?
    Pentair Sand Filter
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Closing soon
    I purchased the TF100, a Speedstir and glycerin filled gauge. The K2006 is less expensive but the TF100 IMHO is a better value for the amount of chemical you get. The speedstir really helps in being able to pay attention to drops and color change without also having to wiggle the cylinder to mix. Very happy with my kit and lost my CYA tube and had a replacement back in my hands quickly so love the customer service (He's a member here).
    Seemed to go through a cheap gauge every other year. The glycerin one is gong on third year with zero issues.
    You can also go with Borax for feel. borax site:www.troublefreepool.com - Google Search
    If you go with Borax you'll need to get test strips for Borax, available from the TFTestkits web site, Amazon, pool stores, ...
    I went with boxes of 20 mule team and gallons of muratic acid. It's more work but it's a lot less expensive IMHO than the borax and acid powder you can order. Going that way is much easier as you just dump it in and you're good. Depending on the pool it can be a lot of boxes and gallons
    dm9287's Avatar
    Jul 2016
    Webb City Missouri
    5
    Re: Closing soon
    Thank you, next up research muratic acid and acid powder.
    Pentair Sand Filter
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Closing soon
    Went to one of the Boric Acid suppliers and noticed that shipping is FREE. That might make a difference in which I'd choose if I were to do it again. That and I think I'm paying $2 more per gallon for muratic acid this year from two years ago when I did the big addition. That powder is looking better and better.
    BTW, In that picture I used the bucket and a small pond pump to dissolve each box of borax before adding it to the pool. Not really necessary as it dissolves pretty easy when just dumped in and brushed around.
    boric | Duda Diesel Alternative Energy, Chemicals & Industrial Supply Store
