Thread: Help. Install of LED PAL TREO 2T2 light
    Jun 2015
    East Meadow/NY
    82
    Hello TFP,
    Looking for advice on the install of a pair of PAL TREO 2T2 LED lights. I have a semi inground Radiant metric free form pool. I had my installer cut into the walls on the same side on each end. They are currently installed in the pool with the wiring looped outside of the pool. When I did the original build I forgot to have him estimate the work to hook them up. Now he's asking approximately $1000 to do the work. That is just crazy! My question is has anyone installed these lights in a semi inground pool? The instructions say that the lights need to be installed in 1 1/2" watertight, underground PVC conduit to 12V AC transformer location. It also says that it requires a minimum of 3 1/2" of straight 1 1/2" PVC pipe behind wall fitting required prior to conduit or bend. Do I need to go 1 1/2" all the way to my transformer or can I reduce the pvc to 3/4" 3 1/2" after where the light comes in?
    Thank you
    14x22 radiant freeform, 6800 gallons, Semi AG, DE Hayward, Hayward SP1580X15 Power-Flo LX Series 1-1/2-HP, installing 7/14/2016, TF100
    Jun 2015
    East Meadow/NY
    82
    Re: Help. Install of LED PAL TREO 2T2 light
