Results 1 to 10 of 10
Thread: Pentair 011018 "DISPLAY NOT ACTIVE!" driving me insane
    Mar 2016
    Woodland Hills, CA
    14
    While I'm trying to program my Pentair 011018. the LCD constantly switches to "DISPLAY NOT ACTIVE!" if I don't press a button for more than half a second. It drives me insane and makes programming the pump 20X more difficult. Is there any way to disable this during programming? Why on earth would they ever even make this a feature?
    Mar 2016
    Woodland Hills, CA
    14
    Re: Pentair 011018 "DISPLAY NOT ACTIVE!" driving me insane
    bump
    Oct 2014
    Sacramento, CA
    72
    Display disabled is only when its hooked up to some type of controller like an easytouch, intellitouch or sun touch in which case you should be able to program from there... is there a black long cable plugged into the side of the pump?
    David Randolph
    Warranty Station
    Pentair
    Jandy
    Owner Sac Pool Pros
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,500
    Toe,
    That is what my Intelliflo says when the EasyTouch is connected... Do you have a standalone pump or is it connected to an automation system?
    Mar 2016
    Woodland Hills, CA
    14
    Quote Originally Posted by Jimrahbe View Post
    Toe,
    I have a Solar Touch (not a Sun Touch) controller for the solar panels, but all that really does is toggle the pump between the speed I set for when the solar warming panels are active, and when they are not. It can't control anything else about the pump (aside from some priming and solar valve related operations). Even if I disable the Solar Touch controller via its interface, I still get the DISPLAY NOT ACTIVE dialogue.
    Jul 2014
    Bedford, TX
    7,500
    Toe,
    When you say you "disable" the Solar Touch, does this mean you remove the connector at the pump end???
    Mar 2016
    Woodland Hills, CA
    14
    No, I just hold down the main button on the Solar Touch for 3 seconds until it says "disabled." After that it is no longer controlling the pump.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    When I disable the Solartouch by holding down the enter button I am able to program the pump from the pump. If that doesn't work then unplugging the comm cable from the pump will work.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    I have the same pump and solar controller and disabling it never works for me. I just disconnect the com cable while programming and reconnect when done.
    chiefwej
    DFW, TX
    24,485
    Hmm, I got mine in May 2014. Maybe it is newer and that is a new feature.
