Results 1 to 14 of 14
Thread: To SLAM or not to SLAM....
    TheBraLady's Avatar
    Jun 2015
    Concord, NC
    177
    Pool was finished 9-1-15 and we have been trouble-free until the past couple days. Might still be ok, but I'm wondering...
    Most important - here are my numbers - just tested about 10 minutes ago: (I do have the proper test kit - I know sig says 2005 kit but I ordered the extra that I needed from TFT)
    FC 6
    CC 0
    pH 7.6
    TA 70
    CH 160
    CYA 60 (maybe 70 - I hate this test.
    Salt 2800
    Borate 30
    Temps have been running 86 - 90 - closer to 90 consistently.
    I also did a OCLT last night and the pool lost exactly 1ppm.
    Water is clear but the past couple days I've brushed off some green spots that have me nervous. And like a dummy I didn't take a picture. Also - we have these lights in the pool:
    Product Detail Overview PAL
    And when I'm checking them out underwater I see green film in the little circular spaces. I don't currently have a brush that will fit those tiny little spaces - on the hunt and welcome suggestions. Toothbrush is too large...
    So I'm nervous and wondering if I should perform a SLAM just in case.
    Thank you for listening! And please forgive me if I posted this in the wrong place...
    Sara
    Pool Completed 8/2015 18'x36' Gemini shape 3.5' - 8', 19,200 gal IG vinyl, Hayward Max-Flo 1.5 HP 2-speed pump, Hayward Pro Series 300-lb sand filter, Hayward AquaPlus SWG, NO Autofill, Dolphin M400 robot, Taylor 2005 test kit, 434 gal Bullfrog A7L spa
    Jun 2014
    15,093
    Re: To SLAM or not to SLAM....
    Sara, if you saw green that quickly clouds or "poofs-up" when you move it, it's probably algae. If you saw the same material around the pool as if it was pollen, then you could consider that as an option. Otherwise ....SLAM. Don't wait. It won't hurt anything. You can still use the pool. With a CYA of 60, your SLAM FC level is 24. If you determine CYA to be 70, increase FC to 28. Don't forget to lower pH FIRST to 7.2 before increasing the FC though.
    As for the lights, I have about the same type. Not much you can do other than remove the protective lens and wipe it off. You can't really do much with the fixture protruding from within the FB wall. The bleach will take care of anything in the water. Make sure to hold the FC until you pass the 3 SLAM criteria.
    TheBraLady's Avatar
    Jun 2015
    Concord, NC
    177
    Thank you so much for your reply Pat!
    The algae vs pollen has me wondering too. Would pollen "poof"? This material - whatever it was - definitely "poofs" when I mess with it - whether it's my foot "stomping" near it or the brush. I haven't seen the offending green since Thursday.
    SLAM it is! I don't want to take any chances!!
    Sara
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    One thing you could do is the OCLT test, but if I see anything green in my pool I too will slam right away...
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    TheBraLady's Avatar
    Jun 2015
    Concord, NC
    177
    Quote Originally Posted by Piolin View Post
    Thank you for the reply! I'm going to get bleach this evening! Taking no chances!!
    TheBraLady's Avatar
    Jun 2015
    Concord, NC
    177
    Ok, so for my sanity and to make sure I don't mess this up - here's my "SLAM diary":
    Knew I wouldn't have the time to properly tend to this the past couple days so just started my SLAM today.
    Tested this am and added bleach to bring levels to:
    9AM:
    FC 26.5 (was shooting for 24)
    CC 0
    Brushed and brushed and brushed! Pump is on high and I also turned on the deck jets for about an hour to let all that good FC circulate thru them. I have turned my SWG off.
    10:45AM tested:
    FC 22.5
    CC 0
    Added 43oz bleach to bring back to 24ppm
    3:30PM
    FC 18.5
    CC 0
    water temp 94
    Added 156 oz bleach to bring back to 24ppm. Brushed again.
    Note: today has been a FULL SUN day and our pool gets hit with it all day.
    My thoughts: last night while swimming I brushed around all the little light places as well as all around our steps. No ladder in the pool - just the built in steps. Saw little "poofy" areas as I was scrubbing those couple places - no other visible green yucks as far as I could tell. Ran the Dolphin overnight as well.
    Will check the levels again after the hubby gets home (5-7pm-ish) as we always jump in as a family to cool off - want to be sure its not above SLAM level so that it's safe for swimming. Water looks great.
    Plan:
    I *hope* this is a SLAM out of an abundance of caution. I plan to keep checking the FC level and adding bleach to keep it at 24ppm. As long as I don't see any more signs of algae and my CC stays at 0.5 or below and I pass the OCLT tonight - is it possible this will have been a 1-day SLAM?
    I am so thankful for this forum. Off to donate in a bit!
    Sara
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Glad you catch the green very early, and didn't procrastinate, yes it could really be a day only, as long as you pass all OCLT criteria you will be done, congratulations 🎊
    Starting day 5/25/2015 INTEX AGP 24'x12'x54" 8,400 gal, with salt and borax, INTEX 3,000 GPH pump with 16"sand filter, WM Hayward Skimmer, Intex SWG CG-28669, 1 1/2" hard plumbed PVC, Lil' Shark Vacuum With Leaf Canister, TF100 test kit, speed stir, K-1766 Taylor salt test
    http://www.troublefreepool.com/conte...art-slam-shock
    TheBraLady's Avatar
    Jun 2015
    Concord, NC
    177
    Update:
    6:30PM tested:
    FC 21.5
    CC 0
    water temp 93
    Added 71 oz bleach to bring FC back to 24ppm. Brushed, brushed, brushed. Who needs a gym membership!!??
    8:30PM tested:
    FC 24
    CC 0.5
    No additions made. Begin OCLT
    No poofs of cloudy dirt or yucky looking spots...come on OCLT - don't let me down!
    TheBraLady's Avatar
    Jun 2015
    Concord, NC
    177
    Update:
    7-27-16
    6:30AM tested:
    FC 21.5 = loss of 2.5 overnight
    CC 0
    Added 185 oz bleach to bring FC to 28ppm. Thinking my CYA really is 70, not 60, so using 28 as my new target.
    7:50AM tested:
    FC 28
    CC 0
    brushed again, extra attention to skimmers. Water definitely looks more "sparkly" today. It's funny how you get accustomed to looking at the water every day and "forget" how it's "supposed" to look. My water hasn't been looking bad, but compared to now it was definitely a little dull.
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    So...did you pass oclt this time?
    TheBraLady's Avatar
    Jun 2015
    Concord, NC
    177
    Shoot no!
    Here's my updated log:
    7-27-16
    9:35AM tested
    FC 29
    CC 0.5
    1:08PM tested
    FC 22.5
    CC 0
    Added 156 oz bleach
    2:54PM tested
    FC 25.5
    CC 0
    Didn't add this time because we're getting ready to swim...brushed all over while we were in pool...even let the girls "play" with the brushes...
    5PM tested
    FC 25.5
    CC 0
    Added 71oz bleach to bring back to 28ppm
    9:20PM tested
    begin OCLT
    FC 25
    CC 0.5
    7-28-16
    6:20AM tested
    FC 23.5 = loss of 1.5 overnight
    CC 0
    Added 128 oz bleach to bring back up to 28ppm
    12:50PM tested
    FC 25
    CC 0
    Added 85 oz bleach to bring back to 28ppm and brushed, brushed, brushed.
    REALLY hoping today is it. My pool is so sparkly!
    Just took this photo:
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    You are very very close... Your pool look amazing... 😊
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Pool looks great!
    TheBraLady's Avatar
    Jun 2015
    Concord, NC
    177
    Ok - so surely this is going to be the night I pass the OCLT!
    3:35PM tested
    FC 21.5
    CC 0
    Added 185 oz bleach to bring back to 28ppm
    5:41PM tested
    FC 29
    CC 0
    No addition. How'd I get to 29?? Was shooting for 28...
    11:45PM tested - begin OCLT
    FC 27.5
    CC 0
    Didn't add anything...
