Results 1 to 7 of 7
Thread: IC 40 Flow light delay
    Jun 2014
    Nj
    13
    Recently I noticed that the flow light is slow to turn from red to green when the pump turns on. Returns show strong flow and filter pressure is 5psi over initial charge with DE. When the pump turns off the flow light stays green for some time despite no flow. I washed out the cell with a hose and also did a muriatic acid wash this morning hoping this will fix it. Any other recs? We are 1 yr into a 3 yr warranty
    Oct 2015
    Burleson, Texas
    178
    I just had my IC 40 replaced after 8 months under warranty due to a bad flow switch. My builder put in the warranty ticket and they were out the next business day.
    21,000 gallons, Salt, IG Gunite, Plaster Finish, Free From, Pentair FNS DE cartridge filter, Pentair Intelliflo-VS pump, Intellichlor IC-40, 2 port fountains, bubbler in tanning deck, Dolphin M400, TF-100, K-1766, Speed Stir
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: IC 40 Flow light delay
    Sounds like a little bit of a built in delay in the circuit. I've never noticed it but it sounds pretty normal to me. Why is it a problem that needs to be fixed?
    Be cautious with washing the cell with MA, each time you do reduces the life of the cell a bit. Especially if you wash it when there is no scale present. Only wash the cell with MA when scale is present. I have not washed my cell in 5 swim seasons.
    Jun 2014
    Nj
    13
    The flow light stayed green despite no flow. They're replacing the sensor under warranty.
    Jun 2014
    Nj
    13
    Just an update. They ended up replacing the entire cell.
    May 2016
    Tallahassee
    71
    Mine did the same thing....I pulled the flow tab out a bit and it fixed it....but I have my swg wired to switch off whenever the pump is off so the flow switch is not important to me anymore....
    20k Gunite 16' x 32' , Hayward c7030 700 sq ft cartridge filter. Pentair Superflo 1hp 2sp pump, Intellichlor IC40 w/ Power Center SWG, Hayward GL-235 Solar Controller, (2) Digital GE Timers.
    Jan 2015
    Anthem, AZ
    188
    be careful. those things can turn into an issue that could explode. there is a key word i wanted to avoid in a forum post, but you get the idea.
    19K IG Pebbletec with attached spa. 60sqft Cartridge filter, Intelliflow VS, 399k BTU Gas Heater, Pentair IC40. Phoenix, AZ, full sun.
