Thread: simple salt above ground pool algae and cloudy problems
    Pickinpaugh's Avatar
    Jul 2016
    Goose creek sc
    1
    Hello. I am new to this site and this is my first post (hope I did right). Are there any tricks to controlling algae and cloudiness, but especially algae in a simple salt system pool? We brush and vacuum and clean filters every other day, we now include clarifier in our weekly routine along with turbo shock, (recommended after last water reading at pool store). We have a simple salt system which means we weekly include shock (shimmer) and a clarifier (vivid). This is in addition to the other clarifier and turbo shock we administer. We've also used an algae preventer in the pool. Our PH and alkalinity readings are always normal. The copper reading is now set at 2. The "mineral" still reads OK, but on the high-end. Any pointers would be greatly appreciated. The pool floor and walls has a slimy feel and we find several of those algae eating swimming bugs in the pool. Is this common for salt systems? We are thinking of going back to the chlorine system. Oh we have a cartridge filter (I.e. no back washing) thank you.
    30' round above ground pool. Simple salt system.
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: simple salt above ground pool algae and cloudy problems
    Welcome to TFP. First, how are you testing your water? My first instinct is to say all the shock is making your cya go through the roof. When cya goes up, you have to increase the amount of chlorine in your pool or it can't sanitize.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,524
    I agree with Defgufman. Many of us here use SWGs successfully. But if you want to augment the chlorine it produces, you should only use straight bleach, aka liquid chlorine. Shock products contain stabilizer, also called CYA, which builds up in your water and requires draining to remove. Too much CYA renders your chlorine ineffective. Please start by reading the Pool School link at the top of the page and order one of the test kits, either the TF-100 or K-2006, recommended by the folks here.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    LFrankow's Avatar
    Sep 2012
    Medicine Hat, Alberta
    502
    Deja Vu from reading your post, you sound just like I did a few years back.
    I also agree with the other two posters as well.
    Get a good test kit.
    I have two gallons of Algaecide and about a quart of clarifier, just never use it anymore.
    The only chemicals in my pool shed now are Muriatic acid, bleach, CYA and vinegar.
    Do some reading concerning CYA to FC relationship, once you get that right it becomes easy to keep a pool shining
    Lou - 13.5K Gal pool, AG Intex 24 X 52"
    19" Sand Filter/1 hp pump, Aqua Trol SWG
    90 sq ft Homemade Solar panels + 80 sq ft Fafco panels, coupled with a SS heat exchanger/Hot Water Tank, Pentair SolarTouch, Taylor k-2006
    domct203's Avatar
    Jun 2015
    CT
    3,584
    Quote Originally Posted by LFrankow View Post
    Why are you putting vinegar in your pool?
    Dom
    Edit: Just realized you have a SWG.... I suspect you are cleaning the cell plates with the vinegar?
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
