Thread: jandy aquapure
    Jul 2016
    Huntington NY
    1
    jandy aquapure
    Can you help with what to do about my Jandy Aquapure it reads Output Fault and the water has started to turn green in my pool.
    Jun 2015
    Mandeville, LA
    109
    Re: jandy aquapure
    Don't know exactly what the problem is but it is obviously not generating chlorine. Dump a gallon of bleach in the pool ASAP to get some chlorine in the pool and keep you from going further down the road to a swamp.
    Completed April 2016: 22x36 3.5-5.5-4 Inground, 17,500 gallons, Aquapure SWG, Jandy 2hp Variable Speed, Jandy 460 Cartridge Filter, Polaris 280, Aqualink PDA4, Jandy Nichless LED lights, Diamondbrite color Steel Blue, Noche Travertine Coping & Deck
    Aug 2014
    Houston tx
    2,525
    Re: jandy aquapure
    Is there a service code number displayed?
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
