Thread: Hayward Pool Heater HF error code
    May 2015
    Warren, Ohio
    20
    Question Hayward Pool Heater HF error code
    So, last night my pool heater had an HF error code on the screen and the blower was running constantly. I powered down the heater and then turned it back on to the same error and blower running.
    This morning the heater seems to be operating correctly without any error codes.
    I'm thankful for the heater working correctly today, but I fear the issue last night is a premonition of things to come.
    I've researched the issue and found that the issue is either a bad gas valve or control board. I went out this morning to test the voltage to the valve to determine the root cause but found the heater operating properly. So, its hard to determine root cause if the heater is working well....
    Do any of the experts here have any suggestions other than wait on a repeat occurrence?
    Hayward 150,000 BTU Natural Gas Heater
    Model: H150FDN
    https://www.hayward-pool.com/pdf/man...iagnostics.pdf
    Troubleshooting steps:
    1. Reset heater, cycle line power off and on.
    2. If the code is still present, the Gas Valve may be defective. If 24VAC is not present at gas valve, valve is defective.
    3. Otherwise, replace the ICB.
    Thanks for your help in advance
    24' AG pool @ 13,500 Gallons
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    Re: Hayward Pool Heater HF error code
    You need to wait till it happens again so you can troubleshoot it. More often than not it is the ICB over the gas valve.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
