Results 1 to 7 of 7
Thread: CYA and Chlorine
    Jul 2016
    plymouth
    3
    CYA and Chlorine
    I understand the relationship of Chlorine and Cya level in that you increase the chlorine from when you start out at zero to like what I have now which is 30ppm cya. I found a comment which sort of was what I was thinking in that although your tester indicates 3ppm in your pool it is not a true reading cos of the amount of CYA in the pool. Its like its being available chlorine but its not Free chlorine.
    If this is true ,is that why it dosent irritate your eyes at 3ppm at 30ppm CYA and at 0ppm of CYA it WOULD be more irritating at 3ppm of chlorine. either way it still registers on the pool pentair and strip testers the same. So it seems to me that if it registers it must be there but in a more inefficient way ie. dosent kills germs as well and dosent irritate the eyes as much.
    Also if this is rubbish then why dont we just put in 3 ppm of chlorine and stick to that level until the cya is way up to 50ppm and stop having to check the chlorine from 1ppm upwards
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: CYA and Chlorine
    Not sure I totally understand what your questions is, but the reason we test regularly is FC is continually being used up by sun and organics. We recommend a drop based test kit that can measure accurately. Generally, it isn't the chlorine that irritates the eyes, (unless it's super high) but the "used" chlorine, the "CC's" or PH that bothers people.
    Oct 2015
    Austin, TX
    83
    I think I had the same question at one point...
    If I may rephrase your question, "If CYA locks up chlorine, don't we only need a little more than what's locked up by the CYA? Why do we need more chlorine as the CYA level goes up?"
    I looked into it and my understanding is that the test kits read chlorine whether it's locked up by CYA or not. However, only the part of the chlorine that is not locked up by the CYA is functional for sanitation. So you need to read both CYA and chlorine, as the CYA level goes up, then you also need to raise the chlorine level to maintain sanitation, as per the chlorine/cya charts.
    Marc
    Pool: 16,000 gallons, 16x31, 500SqFt gunite pool, White Pebbletec interior, built by Cody Pools. Pentair Intelliflo VS-3050 pump, Pentair Clean & Clear 420 Cartridge Filter, In-line chlor with Ultra UV, PV3 Infloor cleaning, Pentair Easytouch-P4 control. TF-100
    Spa: 525 Gallons, Coast fiberglass spa of unknown vintage and suspect previous care with a 2-speed main pump and a blower motor, both 4HP. 3-step bromine sanitized.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    It is bound as a percentage which is why the recommended FC levels are a percentage of the CYA. FC/CYA Chart
    Jul 2016
    plymouth
    3
    ok Thanks PAgirl, Marc and poolDV for that. I just thought why not stick to a single figure of chlorine say 4ppm when cya is 0-30ppm ( in the Uk Im sure we dont need to bring the CYA up to 30 initially cos of our weather), and it would be easier for the first 3 or 4 weeks then check CYA with turbidity, instead of using these charts and testers which go 0.5 , 1.0 , 1.5 , 3.0, 5.0. Saying that there is more of a distance between 3.0 and 5.0 makes it a bit more tricky to interpret. I worked this out the other day so that I can read a higher amount of chlorine in the pool by diluting the sample, it seems correct to me, ...
    normal chlorine test indicates approx 2.0 ppm
    tap water sample = 0.4 ppm
    (50% / 50% reading) = 1.2 ppm
    0.4 + a = 1.2 (50% / 50% sample reading) ...........transpose formula to
    2
    a = ( 1.2 x 2) - 0.4
    a = 2.0 ppm
    therefore........ True Total Chlorine = ( 50% / 50% sample reading X 2 ) - tap water sample reading
    38,371
    Get a bottle of distilled water to use for the dilution and then just multiple the test reading by 2 ... seem easier
    The FC level of the tap water can change.
    Although ideally you should get a FAS-DPD chlorine test.
    Jul 2016
    plymouth
    3
    That seems sensible, thanks. It does seem consistent with the tap water but you are never sure are you.
