Thread: Retangular main drain collects leaves
    Jan 2015
    Austin, TX
    1,095
    I have one of those new rectangular main drains that prevents drowning and I noticed tonight there is quite a bit of junk in it. Probably not that bad because I know stuff ends up in my filter basket but I need a easy way to suck the stuff out of it. Is there a vacuum attachment that I could use with my vacuum that would fit down there and let me suck some of that junk out?
    I am not good enough at diving into my deep end to pull the screws out and I am afraid I would have to do that a lot because we have a ton of trees in our yard. I would love to be able to hook a long hose and a narrow fitting and suck them out every week or so.
    Pool is done! Only took 17 months! - Natural shape in-ground pool: 37x23, 505sq ft, 96ft perimeter, 7ft deep end, 18,950 gallons, tanning ledge, blue surf pebble sheen/luminous blue blend, Belgard coping, 910 sqft paver deck/walkways, retaining walls out the yinyang. Jandy SWG, 2 LED Color lights, VS 2HP Pump, 460sqft cartridge filter, PDA RS P8 controller. My build
    JoyfulNoise's Avatar
    May 2015
    13,231
    Re: Retangular main drain collects leaves
    Short of getting some diving weights and a snorkel mask....no idea.
    Here's a goofey thought - is your MD plumbed to your pad with a Jandy shut off valve? If so, you could take the valve apart and use a Drain King hose bladder with a garden hose to shoot water back through the MD line and blow all the junk out...might work.
    Matt
