Thread: algae
    algae
    what is the best way to get rid of yellow algae, i brush it down and the next day it's back, i have an in-ground pool with plaster???
    30,414
    Re: algae
    You must provide more info to get good advice. Chlorine is the answer but how much and what kind requires more input on your part. Posting a full set of test results will get you the most accurate answers.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: algae
    Quote Originally Posted by mcmacky
    Chlorine. Lots of it for several days. Read http://www.troublefreepool.com/pool-...efeating_algae for more info.
    chlorine
    Threads merged for consistency.
    what is the best powder chlorine??
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: algae
    You don't necessarily want to use powder.
    I would suggest you post a full set of results so we can advise you better. We cannot advise you what kind of chlorine to use without knowing what your current levels are.
    Also, please update your profile to create a signature - we need to know your pool specifics/equipment. This way, you won't have to keep repeating it and we won't have to search for it.
    Go to User Control Panel, the Profile, then Edit Signature. You are allowed 5 lines of text - size, type of pool, surface, various equipment.
    Thanks.
    Jan 2009
    Cupertino, CA
    1,966
    Re: algae
    Powders generally add other stuff along with chlorine. Whether that other stuff is bad or okay depends on what's already in your water. I second the motion for a full set of test results (FC/CC/pH/TA/CH/CYA).
    --paulr
    BBB "Intermediate Swimmer"
