Thread: SLAMing Spa question
    Sep 2015
    Los Angeles
    31
    Should the jets be on the whole time you are SLAMing?
    Thanks!
    1100 gallon gunite IG spa with vanishing edge and 300 gallon overflow basin. Cartridge filter, hayward variable speed pump, finished 11/15/15, Taylor kit,
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: SLAMing Spa question
    if you can get some water to the spa during SLAM it would be good, can you set a valve to 15% or so to the spa? you can also bring it to SLAM level and do them seperate but it could be a pain...
    Sep 2015
    Los Angeles
    31
    I actually only have a spa. I was concerned there might be algae in the pipes.
