Page 1 of 2 12 LastLast
Results 1 to 20 of 37
Thread: green pool help ? first timer
    Jun 2015
    Houston TX
    31
    here are my readings
    FC .5
    TA 110
    CH 225 ppm
    CYA...wont register
    using my TF 100 rest kit for the first time
    thanks Bill
    thanks Bill
    IG, saltwater, intellichlor, DE, pebble, 13k gal
    Pentair easy touch, Polaris
    Apr 2015
    Brookline
    60
    Re: green pool help ? first timer
    Start reading Bill! Head right to the pool school section and get to slaming
    Southern New Hampshire, 18x36 single roman end pool.
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    What is the pH?
    Starting day 5/25/2015 INTEX AGP 24'x12'x54" 8,400 gal, with salt and borax, INTEX 3,000 GPH pump with 16"sand filter, WM Hayward Skimmer, Intex SWG CG-28669, 1 1/2" hard plumbed PVC, Lil' Shark Vacuum With Leaf Canister, TF100 test kit, speed stir, K-1766 Taylor salt test
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Deleted
    Jun 2015
    Houston TX
    31
    can i start slamming when the CYA...wont register....i see the black dot with the thing full?
    thanks Bill
    Jun 2015
    Houston TX
    31
    now with the PH
    FC .5
    TA 110
    CH 225 ppm
    CYA...wont register
    PH 8.2
    thanks Bill
    Jezza's Avatar
    Jan 2015
    Bunbury, WA, Australia
    883
    Start bringing the pH down- it could be higher- so aim to bring it down to 7.5. Use Poolmath at the top for the amount to add. Test 1/2 hour after adding MA and if it is still reading high (i.e. 8.2) repeat. If you are getting a lower reading then you can aim for 7.2 to prepare for the SLAM. You need to get this right first then you can deal with the CYA before then SLAMing.
    11 000 gallons, IG, Fibreglass, Monarch Sand Filter, Davey Typhoon C100M 1HP pump, Davey Chloromatic Mc16CTO ESR SWG, Davey Pool Wall Climba Robot, Daisy Solar Cover,
    K-2006
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Add the CYA, lower the pH and slam hard...follow the instructions to the T
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    HI there
    You need to lower that PH to about 7.2 before SLAM. Used pool math to tell you how much muratic acid to use to lower it. To proceed with SLAM, you'll be spinning wheels losing chlorine to sunlight if you don't bring your CYA up to the 30ish range first. You can buy that at Walmart sold as stabilizer usually. Look for no less than 99% Cyuranic acid on active ingredients. Put it in an old sock and tie in front of a return to dissolve. Or......I've been known to tie them to pool noodles. Just understand that agitating that sock will help the granules dissolve. You really don't want those granules sitting on your pool floor which created the sock method.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Jun 2015
    Houston TX
    31
    Gotcha, found some calcium harder increaser in the pool section at Walmart
    thanks Bill
    Jun 2015
    Houston TX
    31
    thanks Bill
    Jezza's Avatar
    Jan 2015
    883
    I'm assuming that your trying to get your CYA up. You need stabilizer/cyanuric acid not calcium hardener if that is your intention.
    K-2006
    Jun 2015
    Houston TX
    31
    Quote Originally Posted by Jezza View Post
    thanks, i read some more on how to increase my CYA.....they want 40.00 a gallon at the pool store for Leslie stabilizer
    thanks Bill
    Aug 2014
    Northern IL
    4,615
    Try a big box store. Look for 97%+ cyanuric acid on the ingredient label. But work on lowering that pH right away!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,499
    I buy granular stabilizer/CYA in 4 lb jug at Lowes, much cheaper.
    More here on pool chems, Pool School - Recommended Pool Chemicals
    Jun 2015
    Houston TX
    31
    Looks like I'm missing R-0003 from my test kit, so I can't test for CC ? And my PH is still too high
    thanks Bill
    Jun 2015
    Houston TX
    31
    ok, my PH is now at 7.2, and i found the 4 lb Clorox stabilizer at lowes, i have 3 lbs in a sock (in the skimmer basket)
    ....should i start the slam process, or wait till i get a good CYA reading?
    I also back washed DE this morning
    thanks Bill
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    I will assume that you have the necessary CYA and start the slam right now...
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Keep testing for FC every hour or two to maintain the slam level for FC, until it hold the value, then you can test less often, and brush every time you can
  20. Back To Top    #20
    Aug 2014
    Northern IL
    4,615
    Yes, you can add FC and start the slam at your goal CYA level. Squeeze the sock frequently. (I just added some and I had it all dissolved within about 20 minutes with constant squeezing).
