Thread: Tap water test
    May 2015
    Fullerton, CA
    636
    Tap water test
    TA: 200
    Total chlorine: .5
    PH:7.8
    33x19, 3'4"-5'6", 7ft spa, baja reef, 14'x9', 18" deep, 10,668 Gal. Quartzite coping, Stonescape Tropics Blue mini-pebble, abalone & glass beads. Jandy Equip.(JXi heater, 2.7HPVS pump, PLC1400 SWG, CV580 filter, Aqualink, LEDs)
    TF-100, Doheny Discovery robot.
    JoyfulNoise's Avatar
    May 2015
    13,247
    Re: Tap water test
    What test kit did you use to test that? Looks ok but the chlorine seems a little low for municipal supplies. Many have at least 0.5 to 1ppm monochloramine in them which shows up as CCs and sometimes 1ppm or less of FC. It would be good to see a CH reading as well.
    Matt
