Thread: Pool Remodel/ Cracking and Leaking
    Jul 2015
    Fairbanks, AK
    40
    Hello All,
    I just got 40 year old indoor pool drained out as I am helping with a remodel project. The pool has recently had issues with fluctuation in water level. Some days the level will drop a full couple of inches, and other days it will keep a consistent water level. There is nothing leaking pump/plumbing wise and I can not seem to find where this large water loss is going? My thought at this point is it has to be cracking in the pool concrete foundation, as the pool was bonded at some spots years back. I have bought a pool bond kit from http://www.emecole.com/pages/foundat...pair-kits.html to try and reseal cracks? Has anyone used this product? Secondly there is like a check/spring valve at the main drain on the pool that still has water coming up through it after draining the pool shown in the picture. What is this and should water be coming back up after draining? Pictures coming. Thanks for the help!
    Commercial Pool Facility| Pool 35,000Gal, Pentair Inelliflo VS, Pentair Triton II 140, CircuPool SI 35 +| Indoor Spas 12,500Gal, Pentair Intelliflo VS, Pentair Triton II 100, Circupool Si 25+| Outdoor tub 10,000 Gal, Pentair Intelliflo VS, Pentair Triton II 100, Circupool Si 25+
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: Pool Remodel/ Cracking and Leaking
    That is a hydrostatic valve and it's job is to relieve pressure from ground water so the pool doesn't pop out of the ground.
    Jul 2015
    Fairbanks, AK
    40
    So it is normal to have to seal shut the hydrostatic valve when drained, I am assuming that water does not flow up from the valve much when pool is filled?
    Jul 2015
    Fairbanks, AK
    40
    I have to just let it relieve water and cant plug it becuase the pool could pop? We just had a week of rain !
    DFW, TX
    24,509
    No, don't seal it, the pool could float up out of the ground from the ground water.
    Jul 2015
    Fairbanks, AK
    40
    Ok well I am going to replace the hydrostatic valve just to be sure its working correctly because it is letting in a good amount of water and we need to stay dry to resurface.
