Thread: Alkalinity and pH
    Jun 2014
    Newporr,ca
    42
    Alkalinity and pH
    I have a reading of:
    PH- 7.5
    Chlorine- 2
    Alkalinity- 40
    Calcium- 200
    I would like to raise my alkalinity to 100 but I don't want my ph to raise also...
    If I put in 3 lbs of bi- carbonate then my ph will be out of range.
    1500 gallons SPA. 104
    IG, Plaster, 6years old.
    Sand filter Triton ll TR140.
    Taylor K-2006 Complete Pool
    Pentair brominator feeder using bromine. Bi-carbonate. Calcium chloride.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Alkalinity and pH
    Raise TA to 60 with baking soda. 100 is too high.
    Add you pool info to your signature so we can help you better, more here, Pool School - Read This BEFORE You Post
    And more here, Pool School - Recommended Levels
    Jun 2014
    Newporr,ca
    42
    Thank you.
    btw. I revise my signature. thanks.
    DFW, TX
    24,450
    For a spa I would only raise TA to 50. And let pH sit anywhere from 7.6 to 7.8. And if pH rises to fast then add 50 ppm of borates.
    There is good info on pH/TA management for a spa in this article, How do I use Chlorine in my Spa (or pool)?
