Thread: Cant Secure Niche Retaining Ring
    Jun 2015
    New York
    4
    Bought new stainless niche retaining ring (8-hole American Pentair) and the gasket. After getting 5 of the screws in tight, the last 3 screws won't grab the threads of the holes in the niche. Unfortunately, the 3 holes are together, so the ring and gasket won't seal tight. The screws go in, but when they get to the ring, they just keep turning. Screws are 1/4" 20, machine, flat-head. Tried plumbers tape, no good. Tried 2 sizes of plastic wall anchors but they didn't grab and just spun when screws were inserted. I'm tempted to just tap the holes with 5/16" 18 tap to get new threads and then use 5/16 screws. But I'm a little concerned about the filings falling down and potentially cutting the liner. Also, if I vacuum them out, will they rip the filter grids? And if I do the tapping, do I need to drain the water down below the holes?
    Got any ideas? Thanks.
    Jun 2014
    15,059
    Re: Cant Secure Niche Retaining Ring
    Sorry you haven't received any input regarding your retaining ring. You may have it resolved by now, but I wanted to check-in and give this post a just in case. Have a nice day.
    Jun 2015
    New York
    4
    I did a dye test around the niche and it turned out that at the three holes that wouldn't hold a screw, the dye just shot right in all three of them. So I "mummified" the 3 screws with white plumbers tape, even getting a portion of the screw head and screwed them in. That appears to have fixed it, no more leaks.
    Hey, it was worth taking a shot.. It wasn't your basic how to question. You have a nice day.
