shoot - I messed this up.
So yesterday I adjusted the timer for my chlorine injection pump - and I got the AM/PM backwards. So last night my injection pump dumped about 5 gallons (whatever was in the tank) of chlorine into my pool emptying my 15 gallon tank.
The chlorine right now is 23ppm. CYA is at around 70 from the last test (didn't test cya today and don't know if crazy high chlorine would effect the test)
Today is a hot, sunny, Texas day. The pool pump is running and the fountains are on. Anything else I can do to lower the chlorine?
Will it be safe to swim in this evening?
Found this on the Leslie's website. Is it safe to put in the pool? Does it work? How much would I need?Leslie's Chlor Neutralizer Pool Chemical
