Results 1 to 7 of 7
Thread: Sand filter sudden pressure drop
    Jun 2015
    Ottawa/Ontario
    340
    Hi all
    Normal operating pressure, post backwash, is about 12-14 psi. This morning I noticed that the sand filter was reading 8 psi. I haven't backwashed in a couple of weeks (I don't get much debris).
    Any thoughts from the group as to why the pressure would drop suddenly like that?
    Cheers
    Tom
    20000 gallon, IG, SWG, Sand Filter, Hayward 1/2HP + Lorentz direct solsr PV pump
    Aug 2013
    Otsego, MN
    79
    Re: Sand filter sudden pressure drop
    Suction side clog? Pump impeller problem? Suction side valve closed too far?
    Pool/Equipment: 20'x52" round Intex Ultra Frame AGP (~8,800 gallons)--Intex SWCG (CG-28669, 15K gallon model)--Intex Sand Filter Pump (SF60110, 16", 120lbs sand, 3K gph)--Hayward SP1091LX Through-Wall Skimmer--Hard Plumbing--Taylor K-1766 Salt Test Kit--TF-100 Test Kit
    Jun 2015
    Ottawa/Ontario
    340
    Will double check, but I do not believe so. Return lines seem to be pushing water as normal....
    68,000litre, IG vinyl, LorentzPS 600 Solar Pump & 1/2 HP Tristar, Sandfilter, Aquarite T-15 SWG
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,871
    If the return lines feel like normal pressure, I'd replace gauge before chasing ghost problems like clogs. Sure, there could be an issue but I've chased them myself for a week or more just to find out my gauge was going bad. It started reading low pressure for a long time. Then one day it was very high and didn't return to zero when pump was off. Replaced gauge and all was normal. I go through almost one a season.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    30,432
    What do you meqan "sudden"? 10 minutes? 10 days? Sounds like two weeks, is that correct?
    Jun 2015
    Ottawa/Ontario
    340
    Two weeks max....
    30,432
    I would check the pressure gauge. If water is being pushed normally into the pool, you do not have low pressure at the pump intake.....not much, anyway.
