Thread: Phosphate sources, and use of phosphate remover
    Jul 2016
    CA
    31
    I am considering a phosphate remover to help prevent algae growth. (I have read many of the threads here on this topic, and understand that adequate FC levels will prevent algae.) Two specific questions.
    I believe that my pool has very low phosphates, but I want to make sure I haven't overlooked an obvious non-trivial source. I contacted my water utility and found that phosphates in the water supply are below detectable levels (13 ppb). So no major source there. No agriculture or industry nearby (I live in Berkeley, at the foot of the hills, about 1.5 miles from the bay). Pool is covered 18 hours/day. Very little organic debris in the pool. Swimmers are clean. Clothes washer detergent has no phosphates, so no residue there. Small amounts of phosphate presumably from soil, organic matter blow in. Had algae once when FC went to zero by mistake. So I'm thinking I have very little phosphate, and it is the limiting nutrient.
    Question #1: Is there some potentially non-trivial source of phosphate that I could be overlooking?
    Question #2: If my phosphates are as low as I suspect, can i use less than the recommended amount of Orenda PR10000 (to save money) without reducing its effectiveness?
    Last edited by szmad; 07-23-2016 at 02:05 AM. Reason: needed to add Q2; auto-correct incorrectly changed ppb to ppm
    IG, vinyl (27 mil), 12,000 G, Apr 2016, OREQ TK400 test kit
    Pentair Tagelus sand filter, Intelliflow variable speed pump, automatic cl/br feeder
    solar bubble pool cover, full sun ~8 hrs/d, water temp 79-84 F May-Oct
    municipal water supply has low nitrates (<0.4 ppm), sulfates, turbidity, TDS
    don't know about phosphates, but suspect they are low (no agriculture around)
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,278
    Re: Phosphate sources, and use of phosphate remover
    1. A phosphonate metal sequestrant may have been used when the pool was started.
    2. I don't know
    Alternate comment re: question no. 2: To save money, don't use phosphate removers. If measured as achieving something beneficial for your pool, effectiveness is 0 and therefore can not be reduced.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Why do you want to remove phosphates? If it's because it's food for algae, if you kill the algae, it doesn't matter how much "food" is there. Chlorine is much cheaper then any phosphate remover.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    The giganticist phosphate thread of all time is right here,
    Phosphates.....are they worth removing??
    30,431
    Refer to pooldv's link above. That thread covers phosphates quite thoroughly and is open for discussion. I am closing this thread.
