Results 1 to 7 of 7
Thread: Eureka! It works, it really works!
    OutWest's Avatar
    Jul 2016
    El Dorado County, CA
    35
    I have been trying to get a whole lot of gunk out from the bottom of my pool. My new purchase, PoolMaster Max CG arrived yesterday and got charged and used today. I was so dubious about it, partly because of the high price tags, but it is doing the job. I am gong to vacuum again tomorrow and I'm hoping that will do the trick. Yahoo! Now to get the chemistry under control. I may get to swim soon.
    First picture shows deep end after about half the silt had been vacuumed; second shows part of what came out of there; and the third shows the (almost) clean result.
    8,900 gal in-ground gunite lap pool; self-cleaning Jandy 1.5 HP Pro Series E-pump system; Jandy CV340 pool/spa filter with four cartridges; Propane heater (rarely used); motorized pool cover.
    Aug 2014
    Northern IL
    4,615
    Re: Eureka! It works, it really works!
    Vacuums work a treat. You go! I did not peek long at your other posts. How are you testing your pool chemistry?
    OutWest's Avatar
    Jul 2016
    35
    I've been using a standard five test package. I've been reading up on the different kits though, and think I'm going to get the kit with 100 in the name. I think I need to be doing more extensive testing than I have been. I have switched to using bleach and what a blessing that is.
    Mar 2011
    Grand Rapids, Michigan
    279
    You won't regret getting the TF100 kit. Grab the Speedstir also, it's well worth the $$ in my opinion. I have a Blaster also and love it.
    17,500 gal. ABG Doughboy Pool
    1/2 HP Pump/150 sq.ft. Cartridge Filter
    TF100 Test Kit And Speedstir
    OutWest's Avatar
    Jul 2016
    35
    Quote Originally Posted by DebbieO View Post
    Thanks! What's the advantage of the speed stir?
    Jun 2014
    15,059
    Much easier mixing and handling of the reagents during the process. Also facilitates accurate blending which equates to more reliable test results. You won't regret having the speed stir.
    OutWest's Avatar
    Jul 2016
    35
    Thanks!
