Thread: Circupool and my Taylor reading 2 different salinity
    Jan 2015
    San Jose, CA
    237
    I fired up my swg today, I added 400lbs of salt to my 20k pool, which was supposed to be 2400ppm
    I tested with the Taylor test kit by one drop of the first agent then proceeded to adding one drop at a time until it turns to a red color. Counted 27 drops which is 5400ppm
    However circupool reads 2300-2400ppm which lines up with my salt addition. Did I mess up somewhere?
    SF Bay
    ********20,000 gallon IG Fiberglass, DE Filter, Hayward Max-Flo VS, Taylor TF-100 Test, Circupool RJ-45********
    May 2014
    San Jose, CA
    153
    Re: Circupool and my Taylor reading 2 different salinity
    Run the pump for 24 hours and brush the bottom of the pool let the salt dissolve before you test levels.
    Our Build 2016 14.5' x 26' IG Pebble, 14.5K Gal. 3.5' - 6.5' deep, 5 returns, 2 Skimmers, Hayward VS pump, Hayward 525 Cartridge Filter, Hayward E-Command 4, Heliocol Solar, Hayward LED Light, Paramount Ultraviolet, Polaris 280, AquaRite Pro, T-CELL-15, Sense and Dispense (HL-CHEM), Ph Dispense System (AQL-CHEM3) , Taylor K-2006 with SpeedStir
    Jan 2015
    San Jose, CA
    237
    I added salt since yesterday and it was running all night
    I turned off the breaker for half a day while I was installing the swg. I'll keep the pump running tonight and brush tomorrow and test again tomorrow night.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    It takes 24 to 48 hours for the salt to fully dissolve and mix in the water. Salt readings from SWGs and salt tests can be up to +/- 400 ppm. They are really "ballpark" tests.
    JoyfulNoise's Avatar
    May 2015
    13,193
    Did you use a 25mL water sample or a 10mL water sample? The K-1766 uses a 10mL water sample (this is a common mistake). If you accidentally used a 25mL sample then the titration is 80ppm/drop.
    If you multiply your 5400ppm by (80/200), then you get 2160ppm which is dead on with what your cell is reporting.
    Matt
    Jan 2015
    San Jose, CA
    237
    I used only 10ml of water
    Also, after running for the night then circupool isnreading 3400 ppm average. I'll check again later today
