Thread: Clog in suction pipe?
    Hi All,
    I am stumped. I just replaced a pump that I thought was faulty (it was very old anyway) in order to solve a problem of too little water making it to the pump.
    Of course, I was wrong. It is not the pump, as the new pump now has the same issue.
    PSI is normally at 13 without solar panels 8 feet up, and 20 or 21 with. Now the PSI jumps to 30 almost immediately after turning the pump on.
    Snake from pump side found nothing, as did Drain a Blaster from both sides...
    Ideas?
    David
    18,000 gallon, in-ground gunite pool
    Hayward C-1750 Cartridge filter
    3/4 hp pump
    in Sunny Northern California
    Apr 2015
    tucson, arizona
    1,107
    Re: Clog in suction pipe?
    Try running with the cartridge out of filter. Assuming there are no valves closed on return side of pump. Maybe you just need a good cleaning of the cartridge or a new one
    Hi All, KA,
    I did not realize that my post from my cell phone made it, so I inadvertently posted this issue twice. The other, active thread is now simply entitled "Clog?"
    David
    3/4 hp pump
