Results 1 to 7 of 7
Thread: Lights.....what the????
    Feb 2014
    Leander, TX
    33
    So....I've got this nifty 23,000 gallon pool with LED lights. The issue, only one of them appears to be working and it's red. I can't, for the life of me, figure out this dern light controller. I've read it, printed it, etc....but nothing seems to work. I just want all the LEDs "blue" and on...is that so hard???
    I'm not sure what the magic sequence is, but between the manual and my brain, I'm lost! Any thoughts?
    I have a Pentair "Easy Touch" controller....
    Thanks!
    23k gal IG pebble, 48 sq ft Pentair FNS Plus DE filter (FNSP 48) 96 GPM, 1.5 HP WhisperFlo pump, Kreepy Krauly Legend Robot.
    Pool was built in 2011, in Central Texas (Leander, TX)
    Ukie's Avatar
    May 2012
    Export, PA
    83
    Re: Lights.....what the????
    what kind of switch do you have?
    Lagoon shape, 23,600 Gal, steel walls by International Swimming Pools, "ultra-seam" liner by Latham, Pentair 011018 IntelliFlo 3HP Variable Speed Pump, PentAir CCP420 filter, Heat Siphon Z575HP, PentAir IC40 SWG, 2 LED Lights (Pentair Intellibrite 5G, 110V). 4 x 1.5’’return lines, 2 x 2’’skimmer lines, 1.5’’ waterfall line. All plumbing is "TigerFlex" pipe, all lines plumbed individually. Deck: travertine glued over concrete.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,733
    Are the lights set up as intelibrites in the EasyTouch?
    Settings>circuit names> (select the AUX circuit the light is assigned to) scroll through the list of names to PoolLight> return to menu.
    Do the same for the spa light but name it spa light.
    Settings>circuit functions> pool light>set circuit function to intelibrite.
    Do the same for the spa light.
    Through the lights menu, choose what options youd like to happen.
    Lastly, go purchase ScreenLogic 2 (P/n 522104) and make your life easier and more convenient.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Feb 2014
    Leander, TX
    33
    Quote Originally Posted by Ukie View Post
    Dumb question, but how do I figure that out? And/or look?
    Feb 2014
    Leander, TX
    33
    Quote Originally Posted by bdavis466 View Post
    I don't have a spa, so that simplifies things a *little*. But, I did what you said, but it doesn't appear to do anything. I did get the red light to blink and it tried to change colors, but nothing happens when I select "all on" for lights and color "blue".
    Is there some sequence I have to follow? "lights" off....adjust settings....turn lights on? etc...
    Feb 2014
    Leander, TX
    33
    Well, so now another light (green) is on at the opposite end of the pool, the red one is off. ARGH!
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,733
    Find the Sync Lights tab under lighting. That should get the two lights on the same setting.
    When you turn the lights on, you will hear the relay(s) clicking on and off several times. This is how the automation system handles how you would have otherwise turned the light switch that powers the lights on and off a certain number of times to meet a color mode.
    -Brian-
    POOL BUILD
