Thread: Replacing spider gasket in Pentair multiport valve....lube or caulk?
    Apr 2016
    Youngsville, LA
    274
    I'm replacing and old spider gasket that was pretty eaten up on the top side causing it to leak out my waste pipe while in filter mode. The old gasket was glued into place and was the biggest PITA to remove because of all the glue causing the rubber gasket to remain in place in bits and pieces. It literally took me 2+ hours to get all the remains of the old gasket cleaned out. I have some silicone Super Lube that I use on all my o-rings and was wondering if that would be sufficient enough by itself to put on the new spider gasket before installing? I REALLY don't want to glue anything again. If not, would a small bead of caulk be ok? I really don't see it coming out, especially since it is set in the grooves.
    15k Gallon In Ground Saltwater Gunite Pool and Spa w/ Overflow
    Dolphin Nautilus Plus Pool Cleaner
    Main Filter Pump - 1.5HP Pentair Whisperflo connected to Triton II Sand Filter
    Spa Pump - 2HP Pentair Whisperflo w/ 2HP Polaris Spa Air Blower
    Resilience PSC3 SWCG
    Apr 2016
    Youngsville, LA
    274
    Re: Replacing spider gasket in Pentair multiport valve....lube or caulk?
    Anybody?
    Apr 2015
    Brookline
    60
    I would use some lube.
    Southern New Hampshire, 18x36 single roman end pool.
    30,426
    Please do not use caulk. What do the install instructions suggest? Anything?
    Apr 2016
    Scott, LA
    5
    Use a multi purpose grease to VERY lightly coat the new gasket. If it is the correct replacement part...it should be hard to get into place dry...once it's in place and installed...it will stay in place. And don't worry about the grease...with a very light coat..you will never know it's there. Hope this helps.
    B
    ~24 Round 13500gal above ground 4'; Dirt devil sand filter; Hayward Power-Flo 1 hp
    TF-100...BBB with BioGuard Burnout 73 when I am gone
