Results 1 to 11 of 11
Thread: Help algae and cloudiness
    Jul 2016
    Gansevoort
    6
    My pool was green I have a 18 by 48 Coleman pool last night I added 3 bags of shock it is no longer green but it is very cloudy how would I get rid of the cloudiness? I also still have a very high chorline level
    Jun 2014
    15,205
    Re: Help algae and cloudiness
    Hello and welcome to TFP! You still have algae in the water. You need to kill the algae following the TFP "SLAM" page (link below). Follow the instructions on that page and it will work. Make sure you have one of the recommended test kits to test the water properly during the SLAM (TF-100 link below). Nice to have you with us.
    Jul 2016
    Gansevoort
    6
    I am a first time pool.owner sorry for being confused but what does swg stand for?... My levels are chorline has been a 5+ since I started testing this morning do I still need to add chorline even though it is still high and I don't seem to be losing any?..pH is 7.2....alk is 80 and hardness is 160
    Jun 2014
    15,205
    SWG is for Salt Water Generator. It converts salt into free chlorine so you don't have to manually add bleach. Is your FC too high? I doubt it, and since you need to do a "SLAM" I can almost guarantee it's not high enough. But to know how high your FC "should" be, we need to know your CYA (stabilizer) level. But you need to test that yourself with one of the recommended test kit (TF-100 or Taylor K-2006). Do not trust pool store testing. It's almost never reliable.
    When you have algae and it goes from green to cloudy, the organics are still alive and in there. A simple shock from pool store powders won't do the trick. That's where the "SLAM" comes into play.
    Jul 2016
    Gansevoort
    6
    My cya is 40,tested myself
    Jul 2016
    Gansevoort
    6
    I also added another bag of shock as I can not make it back to store tonight..so tomorrow I should start with liquid chorline or bleach? How will I know right amount ? By the chorline levels?
    Jul 2016
    Gansevoort
    6
    Retested today chorline is still above 5...pH is 7.5...ta is 100 hardeness 160 and cya 40 going to get bleach today just not sure how much to add
    Jun 2014
    15,205
    Okay, so with a CYA of 40 your SLAM FC level should be "16". You need to use regular liquid bleach to raise and maintain an FC of 16 until you pass the 3 SLAM criterial. I wouldn't worry about any other testing now other than FC and CC. Hope that helps.
    Oh, make sure to lower pH to 7.2 BEFORE raising the FC to 12.
    Jan 2015
    Austin, TX
    1,095
    Also make sure you are using the appropriate FAS/DPD chlorine test. It sounds like you are using the OTO color scale test because you said your FC is >5. You'll want to make sure to use the FAS/DPD so you can determine exactly how much chlorine is in your water. Also are you using the R-0013 reagent CYA test or something else?
    Pool is done! Only took 17 months! - Natural shape in-ground pool: 37x23, 505sq ft, 96ft perimeter, 7ft deep end, 18,950 gallons, tanning ledge, blue surf pebble sheen/luminous blue blend, Belgard coping, 910 sqft paver deck/walkways, retaining walls out the yinyang. Jandy SWG, 2 LED Color lights, VS 2HP Pump, 460sqft cartridge filter, PDA RS P8 controller. My build
    Jul 2016
    Gansevoort
    6
    Yes I got the hth 6 way test I will have to get a better test tomorrow ..the water was more clearer today i could see the bottom a little bit..I vacuumed a lot of algae from bottom of pool today and it also took a lot of water out will that affect the slam? The pH was at 7.2 before I vaccumed should I retest before adding the bleach? Sorry so many questions just want to do it right thanks for the help
    Jun 2014
    15,205
    Vacuuming to waste might in time lower CYA a little, but nothing to worry about right now. Your pH should still be good. Just make sure to order the proper test kit as soon as you can which will also contain THIS ITEM which you will need to perform the FC testing.
