Thread: Do I chlorinate while SWG is being replaced?
    May 2014
    Annapolis
    2
    My Intex Krystal Clear SWG died unexpectedly. It will take 10-20 days for them to replace; how do I maintain chlorine levels in the meantime? How many tabs? How often? I have the testing strips and Total chlorine and FC was low (0.5 ppm) PH 7.2.
    Pool is 22x52 above ground pool with sand filter.
    Above ground 22x52
    Jul 2015
    Central Valley CA
    1,106
    Re: Do I chlorinate while SWG is being replaced?
    Welcome to the forum
    No tabs unless your CYA is low. Get some regular household bleach not splashless or scented. Or you can get stronger liquid chlorine from many hardware stores or the pool store it is all the same thing just in different strengths. Household bleach is 8.25%, pool liquid chlorine is either 10% or 12.5% it will say on the jug. You can use pool math link at the top of the page to determine how much to add once you put the volume of your pool.
    Just so you know the strips aren't all that accurate a good quality test kit can make a world of difference. The kits we recommend are listed in Pool School I believe the TF-100 in my signature is the best
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    If your SWG is combined with the pump and filter and none of it is working use the liquid chlorine/bleach and brush the pool to mix it in.
    Love TFP? Become a
    TFP Supporter!
    May 2014
    Annapolis
    2
    Thank you. The CYA is also low and this morning it appears the PH has also dropped to 6.8 (again that's according to the strips). I will repost numbers once I get the appropriate testing kit. I am a bit nervous about the water because we planned to swim today given our temps will top out at 105! Will the addition of the 10% liquid chlorine help to increase PH or do I have to add soda ash for that and the liquid chlorine? Not having any of these issues until now I am not sure what to do or which one to adjust first. Then how long before we can swim if I add any of the chemicals?
    Thanks!!
    Above ground 22x52
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,176
    Liquid chlorine will not affect the pH, you will need to use the soda ash, or even easier because you can get it at any grocery store - Borax. Borax is available as 20 Mule TeamŽ Borax Natural Laundry Booster. It is sold in the laundry detergent section of most larger grocery stores and some big box stores. Borax is best added by pre-dissolving it in a bucket of water and then pouring that slowly in front of a return. If your pump is not working then brush it around to mix well. Use Pool Math to calculate your needed addition.
    Do not use pucks, even if your CYA is low - pucks (trichlor) is/are very acidic and they push the pH down even further than it is.
    Support the site
