Thread: Super chlorinate ????
    rolo918's Avatar
    May 2015
    Macomb mi
    95
    I have a Hayward T 15 cell 40,000 gallons when I click on super chlorinate how much chlorine will the generator and dumping in a 24-hour period The criteria of my pool is in my Sig
    Chris- Macomb, Michigan 20,000 gallon pool IGP. 16 x 32 Hayward Ecostar pump. Hayward 24 inch sand filter with Zeo sand. Hayward Aqua plus P4 automation board with T-15 turbo cell. Hayward H150 heater millivolts style. Polaris 9300 robot vacuum. New maytronics titain plus vacuum cleaner Test kits TF-100 and color Q7 TEST KIT.http://tftestkits.net.
    38,281
    Re: Super chlorinate ????
    We do not recommend the use of superchlorinate function. It is just too slow. Use bleach if you need to quickly raise the FC level.
    The T-15 is rated at 1.4 pounds of chlorine gas when generating 100% in 24 hours. Using PoolMath, that is 8.4ppm of FC in a 20k pool in 24 hours.
