- Apr 28, 2016
- 103
- Fiberglass
- Pentair Intellichlor IC-40
We have had our pool for several weeks now, and I just cannot seem to get my water to be the crystal clear I know it can/should be. I can see the bottom without any problem, but there just seems to be a haze in it. I did a SLAM about a month ago due to a total loss of cholrine (no CYA) and a film starting to form on the water surface (first pool and new owner mistake). The water got pretty clear after, since then, my FC has been dropping slowly. I did an overnight chlorine test a couple of times and it is always less than 1ppm. However, I have had to crank my SWG way up (85%) to keep up (PB said I should be somewhere around 35-50%). I have not let the FC drop below 3 since the SLAM (I have had to add a small amount of bleach to keep up though). My PB was out yesterday and took a look. He tested for phosphates and said they were through the roof (+5000ppb), so he added some phosphate remover and gave me instructions to get some test strips and keep cycling the remover until they are below 1000ppb. He said that they could be coating the SWG plates and causing it not to work as efficiently as they should. He also threw in a bag of shock to get my chlorine up. He said that that should help clear things up. The rest of my last round of test results are below. I know my TA is high and I am working on that slowly. The CH is high as well, but not much I can do due to my fill water also being high. I am just wondering if I am still on the right track, or if there is something else I should be doing. Thanks for all of the help here.
FC= 3.5
CC= 0.5
PH=7.5
TA=230
CH=550
CYA=60-70
FC= 3.5
CC= 0.5
PH=7.5
TA=230
CH=550
CYA=60-70
