Results 1 to 14 of 14
Thread: Before I go any further I need a lot of honesty!!!
    Hi, I have a foxx pool about 27000 gallons If I remember correct, my numbers are all pretty bad especially my cya its at 100. My question should I drwin some of the water out and start from there or get my numbers right and chlorine the heck out of it???
    FC......16
    CC.......point 5
    ph......7.2
    alk......40
    cya......100
    My Pool:
    Foxx Pool Grecian style 19' X 39'
    27k, with a sand filter=300 lbs of sand
    vinyl liner
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Before I go any further I need a lot of honesty!!!
    Drain and refill first, otherwise you're just throwing money on chems out the drain hose.
    Butterfly's Avatar
    South Carolina
    10,045
    Totally agree. Drain and refill first.
    You're done SLAMing when:
    11,969
    BTW, if you're CYA weren't so high all you would need was some baking soda.
    Can you create a sig....go to User Control Panel, the Profile, then Edit Signature.
    What kind of filter do you have? If you have a sand filter, you want to drain enough to target about 60-70 on your CYA, and backwashing the sand will mean the level drops slowly over the season.
    Be careful with draining, you don't want to drain too much, to avoid damage to the pool. Do you know what your water table is? Usually it's safe to drain about 1/3, refill, retest, repeat if necessary.
    30,403
    If the numbers were from a pool store or any other source than your own testing, I would get them tested again to confirm your CYA level. (Probably your TA, too. I suspect that number may be inaccurate)
    If you get confirmation that it is 100+, certainly drain and get it down to around 50 and then go from there.
    since my water is being partally drained
    Threads Merged. Please keep your pool related questions together on one thread. Moderator.
    What can I use to clean my stairs back to the white that they need to be or are they too stained???
    My Pool:
    vinyl liner
    11,969
    What kind of pool do you have, vinyl, plaster? What material are the steps made of? What kind of stains are they?
    steps are some sort of vinyl not positive they are the walkin step, they are dingy and since I am draining I thought I'd try and clean them
    My Pool:
    vinyl liner
    Sorry for double posting, I have drained a dang good bit of the pool and only cleaned the top stair with acid but clean as a whistle. However I started filling pool back up so I can get the darn thing clear. And I am a bit afraid of draining too much of pool, because we have had loads of rain here lately. All this being said is there a cleaner that works good underwater that will get my steps as clean as the acid did on the top stair? If I didn't fear doing damage I would hae drained enuff to clean all 3 steps cause that is some more pretty white versus the yellow/orange/brown look.
    My Pool:
    vinyl liner
    You could use a sock with dry acid in it, wipe it around slowly on the underwater steps, and it should have about the same effect as liquid acid on the upper step.
    NICE TIP !!!!
    25,000 gal IG Utopia pool/Raypack gas heater/BBB
    You say nice tip, I say awesome site. Everyone here has had some positive input, totally refreshing. Now if I can just get the pool straight I can get totally refreshed.
    My Pool:
    vinyl liner
    Exactly what kind of dry acid would you say?
    My Pool:
    vinyl liner
    11,969
    Sodium Bisulphate.
