Results 1 to 7 of 7
Thread: Let the flow switch do the control or put it on the timer?
    Jan 2015
    San Jose, CA
    237
    the RJ45 instruction say that if using a VS pump, it's possible to let the flow switch turn the SWG on and off. But I also read somewhere that say not to do this...
    My pump run on various speed/hours between 11am to 10pm. @ 2k, 2.4k and 3k rpm. I can set the timer for the SWG to turn on and off between these hours. But I'm trying to avoid having to mess with changing the pump schedule.
    SF Bay
    ********20,000 gallon IG Fiberglass, DE Filter, Hayward Max-Flo VS, Taylor TF-100 Test, Circupool RJ-45********
    Aug 2015
    Orlando
    116
    Re: Let the flow switch do the control or put it on the timer?
    I've read here that the timer is the way to go, as its bad on the cell to have it on without a flow, could in some cases even explode. Wasn't a decision I had to make, as my VS pump won't control SWG, so I set the timer and pump to run at same times, to avoid any issues. Pump is 'hot' all the time so I can run the pump for cleaning by itself, without SWG, but not vice-versa
    Phil
    ~9600 gal gunite pool, NEW July 2015; Pentair Intelliflo 2 VST pump; Pentair C&C 150 filter; Pentair Intelliclor IC40 swg; solar heat w/ Pentair Solartouch controller, screened. Taylor K 2005 test kit, FAS-DPD separate test, Taylor K1766 salt test
    Jan 2015
    San Jose, CA
    237
    what's the min flow rate that's required for the SWG to work properly? perhaps I can turn the SWG by the timer only during the time of the appropriate speeds.
    SF Bay
    38,354
    What SWG do you have? I think the Hayward requires about 15GPM, but there is no way to easily know the flow rate you achieve at a given RPM without a flow meter. Just see what speed is required to keep the SWG happy and bump up the speed a bit to account for the filter getting dirty.
    Jan 2015
    San Jose, CA
    237
    I got a Circupool RJ45... that's a good idea, I'll just get everything hooked up and play with the speed until it turn off and on.
    SF Bay
    Jan 2015
    San Jose, CA
    237
    beside the flow direction, does it matter the position of the switch? Can it be installed side way instead of putting up?
    SF Bay
    Feb 2009
    Hampstead, NC, transitioning to Perfection, NC
    360
    The instructions show that the wire connection should be on top, unless it is installed vertically (ref:Circupool Salt Chlorine Generator Help) Whether that is so the flow switch isn't fooled by an insufficient flow or not isn't revealed.
    16X32 AB, Pentair SD filter, 3/4hp Pentair Optiflo, CircuPool RJ30+ swg, TF 100, 19 X 37 igv, Pentair filter, 1hp Pentair Superflo pump.
