Thread: Filter basket keeps draining water.
    May 2016
    Knoxville, TN
    7
    This is our first year with our pool and I've read and watched some YouTube videos and can't figure out why our filter basket keeps draining water. I have followed the steps in the manual and the basket fills with water normally but once the filter is turned on the water drains back out and the filter basket is full of air again.
    I've read some posts and videos on priming the pump but, I'm confused because we don't have all the same parts as most of the tutorials show. When I open the lid to the filter basket it always fills with water. I read to put a tennis ball where the skimmer basket would go to keep the water from flowing out since we don't have a valve to shut off the water flow. From the pump picture I'm including we just have another hose going to the skimmer basket on the pool (no other valves or anything) I'm not sure what we're doing wrong.
    Thanks!!!
    May 2016
    Knoxville, TN
    7
    Re: Filter basket keeps draining water.
    I just tried backwashing it again and rinsing and its doing the same thing. I open the lid to the basket and water rushes out. I put the ball in the skimmer hole and turn the dial to closed and the basket stays full of water. I place the lid back on and everything looks good. Remove the ball, turn it back to filter, turn it on. Everything looks good but about 15 seconds later all the water has drained out of the basket again. What is going on?!
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Suction leak probably from lid O-ring. Did you lube the O-ring with silicone lube or majic jacks?
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    May 2016
    Knoxville, TN
    7
    Quote Originally Posted by banditig View Post
    No, the rubber ring is just dry? Is it supposed to be lubed?
    dsmith99's Avatar
    Jun 2016
    SW, Iowa
    222
    Are you sure you have enough water in the pool?
    My skimmer weir will sometimes interfere with water getting into the skimmer and that in turn causes the pump to draw air and lose suction. This happens if the pool gets near the midway point of the skimmer opening. As long as I keep the pool level about 3/4 up the skimmer it works fine.
    When you turn the pump on watch inside your skimmer and see if the skimmer remains full as the pump pulls water, if not add some water to the pool and see if that helps, also make sure the weir moves freely and isn't binding on the skimmer box.
    If the skimmer stays full and the pump loses suction you must have an air leak as described earlier, the most likely place would be the pump basket lid. With an above ground pool an air leak is less likely because the pump is usually well below water level so the pump has water pressure on it full time. If the pump lid is not sealed then water will be leaking out before the pump is started.
    AGP 24' x 54" approx 14000 gal Full sun all day, Hayward 1.5 HP and EC50 D.E. filter
    Stenner 45MPHP10 10 gal/day fixed rate with intermatic ET1125C timer
    Dolphin E10 robotic cleaner, 330 gallon Tiger River Spa, Taylor K-2006C test kit
