Thread: Pump on or off to test FC?
    Mimipell521's Avatar
    Jul 2016
    Holden, Maine
    66
    Quick question: I have been doing a TON of reading on here and I vaguely remember someone saying the pump should be running at least 30 minutes BEFORE testing? I can't find the thread it was in now. I know it has to run at least 30 minutes after adding chlorine, so did I misread this? I'm second guessing myself now...
    Basically, I want to know if it's OK for me to test first thing in the morning with the pump having been off all night, or if you should only test with it running...
    Thanks!
    27' round (18,000 gal) above-ground, vinyl-lined, metal surround, with a deck around half. Hayward "Pro-Series" sand filter. Taylor 2006 test kit.
    Jun 2014
    14,957
    Re: Pump on or off to test FC?
    Yes, if you are going to grab a water sample for testing, it's best to that water has been circulating for about 30 min so you get a good reading that represents the entire pool's chemistry.
    Jul 2016
    Holden, Maine
    66
    Ah, ok, duly noted. THANK YOU!
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,224
    Give it a brush while you're waiting. Pool maintenance done, plus water stirred up even better
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
