Thread: Pool pump automation
    careingemt's Avatar
    Sep 2013
    PA
    143
    Hello
    I'm interested in turning my pool pump on / off. I've read it can be done with a Raspberry pi... Any input would be appreciated
    Thanks
    Fran
    AG 18 feet accross 52" high pool wall 7000 gallons .... pool math = 7600
    Hayward extreme cartridge filter 100sq feet
    pool is heated by propane Hayward heater
    pool installed aug 12 2013
    May 2016
    Troy IL
    476
    Re: Pool pump automation
    Or an arduino. You just need to program something to send voltage to a relay switch that will handle the pump load. My pump is 120v and I think a max of 16amps. So I'd need a relay that can handle the 120v/16amp draw.
    I've got an arduino sitting around that I hope to soon build a pool sensor type thing for my setup. I didn't plan to automate my pump, but now that you make me think about it, it wouldn't be hard. Maybe I will.
    If you are looking for something someone else has already written to control your pool, I haven't really found a good one.
    17,500 gallon IG Vinyl
    Pentair Tagelus TA60D Sand filter
    Pentair Challenger 1.5HP pump CFII N1 1.5A
    Taylor K-2006-A, Stenner 45MPHP10 auto chlorine feed
    careingemt's Avatar
    Sep 2013
    PA
    143
    I don't own a Raspberry pi ... Well not yet...
    careingemt's Avatar
    Sep 2013
    PA
    143
    I have no programing experience .. well mabye a little I use an app called Tasker ... I wonder how much experience is needed to work with rpi
    careingemt's Avatar
    Sep 2013
    PA
    143
    Quote Originally Posted by careingemt View Post
    Sent from my Nexus 6 using Tapatalk
    VERY EAGER TO LEARN
