Thread: Do I need a solar cover?
    LittleTagAlong's Avatar
    Jun 2016
    Amarillo TX
    119
    About to go on vacation and no one to watch pool and I can't leave filter or SWG running. Plan to SLAM. Would it help to have solar cover? Have mosquito net covering pool now.
    Please understand : THE FILTER WILL NOT RUN WHILE I AM GONE
    AG, Intex 18' x48" Easy Set pool( =/- 5455 gal)
    Intex SF80110 sand filter & SWG ECO 7110, Hayward AquaCritter
    Well water, location is north Texas, usually up from late May to Oct.
    Taylor TF-100 test kit, TDS Digital Salinity meter and Taylor salt kit
    Jun 2015
    Ottawa/Ontario
    340
    Re: Do I need a solar cover?
    How long will you be gone? I would leave it off, since the cover would lead to an increase in CC. What is CYA concentration?
    68,000litre, IG vinyl, LorentzPS 600 Solar Pump & 1/2 HP Tristar, Sandfilter, Aquarite T-15 SWG
    20000 gallon, IG, SWG, Sand Filter, Hayward 1/2HP + Lorentz direct solsr PV pump
    Jun 2016
    Amarillo TX
    119
    Plan on being gone abut 8 days. Right now my CC is 0. The CYA is 75
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    You could take FC to shock level for your CYA, FC/CYA Chart. A solar cover will significantly reduce FC consumption and will also substantially reduce evaporation and PH rise.
    Jun 2016
    Amarillo TX
    119
    So should I wait to add Boric acid til I return and get it stabilized again?
