Thread: New Pool in MN! Radiant vs Fabcote Ultimate
    Jul 2016
    Twin Cities, MN
    72
    Hi all! I just found this site and am in pool heaven. My wife and I are about ready to jump into the pool life and we have two bids from two solid companies in our area. We are trying to decide between an 18x34 oval Radiant semi-inground vs. a Fabcote Ultimate Pool. Either will be modified to have a 6' deep end in it so we can have a slide attached to the deck that will surround it. The Fabcote is a bit pricier for a slightly smaller oval at 17x32 but it has a 14 gauge zinc coated steel wall while the radiant uses the insulated aluminum wall. When looking at the samples the steel seems much more sturdy that the radiant but then I read about how strong the radiant is. I am leaning towards the Fabcote but only really out of ignorance of materials. Maybe the aluminum is enough? Any advice would be greatly appreciated. If I can offer any more info to help please let me know. As I don't know what I don't know!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: New Pool in MN! Radiant vs Fabcote Ultimate
    Welcome to TFP and congrats on the new pool!
    Jul 2016
    Twin Cities, MN
    72
    Thanks very much! I am finding all sorts of good info here so far. What a great site!
    Feb 2017
    Fargo ND
    3
    Quote Originally Posted by lmisko View Post
    I'm looking at the Fabcote Ultimate Pool. Curious if you went with it, and if so, how has it been?
    Jul 2016
    Twin Cities, MN
    72
    Wow. I forgot I even wrote this post. We did end up with a pool but went with in ground instead. Sorry for the delayed response.
    31600 Gallons, IG, Vinyl, Sand, Pentair Intelliflo 2 VST, Raypak NG Heater, Automatic Pool Cover, Installed Fall 2016, K-2006C Test Kit, Polaris 9450 Sport Cleaner, Hard City Water
