Thread: Water cloudy
    Aug 2015
    ny ny
    24
    Water cloudy
    Been doing the ABC method on here this summer and love it. Right now my pool is cloudy and I can't figure out why
    I've started slamming it so my readings are
    FC 15
    CC 0
    pH 7.4
    Ta 140
    Cya 35
    I did use tablets for two weeks to bump up the cya as it was well below 30. Could that be why it's cloudy?
    I've backwashed a few times this summer too so not forgetting that.
    Thanks!
    33000 gallon vinyl IG pool. s240 hayward sand filter. Full sun in NY area.
    May 2015
    Land O Lakes, FL
    527
    Re: Water cloudy
    Could it be that your FC go below the minimum for your cya?
    Do a OCLT to determine if there is something growing.
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    Jun 2014
    15,128
    Re: Water cloudy
    Once you are sure about your CYA reading, round it up if at X5 or above (i.e. 35 = 40) so that your FC would be 16. The Chlorine/CYA Chart is designed that way as we don't try to "split hairs" and go in between readings. If you failed the OCLT, then happy SLAMming.
