Results 1 to 7 of 7
Thread: Issue with CC reading on TFT 100?
    May 2015
    Stillwater, NY
    3
    New to TFP and after recieving my test kit (TFP 100) I am unable to get the CC reading to work. I follow the below instruction and the solution doesnt turn back to clear. The last test went to 50 drops and the solution seamed to turn a deaper shade pink if anything. Am I missing something? Faulty reagent?
    5. To test for Combined Chloramines, add 5 drops of R-0003 to the solution and swirl. If it remains clear, you have no CC’s. If it returns back to pink, add R-0871 as before, counting and swirling between each drop. Once the solution returns clear, multiply the added drops times .5 again…..this will be your CC reading. Record it. The total of FC and CC should be recorded as TC (total chlorine)
    IG, vinyl, 28k gal, 2007 / Pentair Pinnacle 1.25 HP pump / FNS Plus DE filter / Hayward tab feeder / Pentair Prowler cleaning robot / TF-100 test kit
    Jun 2015
    Glendale, AZ
    156
    Re: Issue with CC reading on TFT 100?
    You do the FC test...after counting to clear, you then continue with the 5 drops....
    Valley of the Sun, Arizona.....10k gunite/pebble (Re-surface March 2015) w/in floor Caretaker 99 cleaning heads -- Pentair FNS 60 DE filter -- Pentair IntelliFlo Variable Speed for pool -- Pentair Wisperflo 1 HP for boulder waterfall...Taylor K-2006 & Taylor K-2006C kits
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Here is a more in depth set of directions. Pool School - FAS-DPD Chlorine Test
    May 2015
    Stillwater, NY
    3
    Quote Originally Posted by pooldv View Post
    Thanks! My problem is the second part of the test never goes clear. I will try adding a larger scoop of the R0870 powder and try to progress through the test a little more quickly. That may be the problem. Could my CC be over 25ppm or is that not possible?
    After the 5 drops of R-0003 you are switching back to R-0871 to count the drops, correct? Not continuing to add R-0003?
    DFW, TX
    24,450
    Not possible.
    May 2015
    Stillwater, NY
    3
    Quote Originally Posted by enoshixi View Post
    This is exactly what i was doing wrong. Figured it out the second time through the test. Beginner mistake. CC of .5!
    Thanks for all the responses!
