Results 1 to 9 of 9
Thread: I need serious help
    Jul 2016
    Lake Charles, La
    4
    I need serious help
    For the past few weeks I can't get rid of the algee. I have put almost 2 gallons of algeeside in the water and 10
    Lbs of shock. I would wait the said amount of time and vacuum to waste. I back wash every few days. The other day the lady at the pool place said not to do that cause it is just wasting out all my chemicals. My ph and ta are almost non existent. I have put in 5 plus lbs of borax and baking soda. I have an In ground vinyl pool 25,000 gallons and a Sand filter. What I am doing wrong?
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,867
    Re: I need serious help
    Welcome to TFP
    What we teach is about accurately testing and balencing our pool water and feeding it only what it needs. We generally don't trust test strips or pool store testing as they all have been proven to be inaccurate. I'll put some links at the bottom of this thread that should help. But first, Algaecide doesn't kill algae.....it is a preventative at best. Many algaecides contain copper which can turn water greenish and cause metal staining over time. So I'd say stop with that for sure. Some links below are a good place to start and post back with questions.
    Pool School - Test Kits Compared
    Pool School - SLAM - Shock Level And Maintain
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Jul 2016
    Lake Charles, La
    4
    Ok I read the links you sent. The one on slamming the pool. What if I can't rise my ph it is around 6.3 or so?
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,867
    Hi there
    How are you measuring your PH? You can raise it a number of ways. You can add borax, you can also aerate your water to raise PH.
    Can you tell us how you chlorinate your water normally?
    Jul 2016
    Lake Charles, La
    4
    I tried that I about between 10-15 Lbs of borax and baking soda and it didn't raise it at all
    I have an chlorinatorthat take 3 in tabs. I have been shocking it like crazy and I even got the little floating chlorinator that has 3 inch tabs in it too
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    Your pH is probably lower than the test can read. I suspect that the tablets have caused the pH to crash. They are very acidic and will lower the pH. I also suspect your pool has a very high CYA level. Do you have a set of recent test results you can post?
    Love TFP? Become a
    TFP Supporter!
    Jul 2016
    Lake Charles, La
    4
    FC over 18.24 ppm
    TC over 18.24 ppm
    CC 0 ppm
    PH under 6.3
    Hardness 29 ppm
    TA 0 ppm
    CYA 40 ppm
    Copper 0.4 ppm
    Iron 0.1ppm
    When I did it the TA test myself I put the initial 5 drops and it immediately turned red not sure if that means it high or low. The chart doesn't tell me that.
    30,408
    Your serious help is available but you must do some serious reading and get a serious test kit.
    Your pH WILL come up. read "The ABC's of Pool Water Chemistry" up in Pool School to tell you how....you just haven't added enough borax.
    Pool store testing won't help you. If you want to truly manage your pool, you must start by doing your own testing.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    Enter your test results in PoolMath. Copy everything over to Target except PH. Make the PH Target 7.2. Add as much Borax as it says, pump on, brush and retest in 15 minutes. Repeat until the PH reads 7.2 or above.
    PoolMath link is at the top of every page. There is a link to the instructions at the top of the PoolMath page.
    Here are the ABCs, ABCs of Pool Water Chemistry
    I use the TF-100 Test kit. It is the best value. I buy mine at TFTestkits.net.
