Thread: I did some calculations based on current chlorine pricing...Leslie's is a good deal?
    Nov 2015
    San Diego, CA
    25
    With the recent Walmart rollback rollback of the $2.50 10% chlorine I decided to do some calculations using current prices. I have come to the conclusion that Leslie's Pool 12.5% is the best deal. I am in no way affiliated with Leslie's. I just want the best bang for my buck.
    Here are my calculations...if my logic is flawed, i'd like the feedback.
    Current prices:
    8.25% $3.09 Walmart 121 fl oz
    10.0% $3.43 HD/Lowe's 1 Gal
    12.5% $4.50 Leslie's (sold in two pack) 1 Gal
    To increase 15,000G pool 1 ppm according to Pool Pal
    8.25% it takes 23 fl oz (5.26 ppm/bottle)
    10.0% it takes 19 fl oz (6.74 ppm/bottle)
    12.5% it takes 15 fl oz (8.53 ppm/bottle)
    so if I had to raise my pool 1ppm per day i would go through
    @ 8.25% 1.3 bottles per week roughly
    @ 10.0% 1.0 bottles per week roughly
    @ 12.5% .82 bottles per week roughly
    Cost per month assuming 4 weeks in a month
    $16.07 for 8.25%
    $13.72 for 10.0%
    $13.44 for 12.5% (WINNER)
    So is this right? All bets are off if Walmart sells for $2.50 again.
    Chris
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: I did some calculations based on current chlorine pricing...Leslie's is a good de
    The higher concentrations will tend to degrade faster so although they say it is 12.5%, it may not be that by the time you get to use it. Especially since some places stock outdoors in the heat.
    Mark
    Chasmengr's Avatar
    May 2016
    Omaha, NE
    156
    Quote Originally Posted by Chris_N View Post
    Current prices:
    Chris
    Try this handy online tool; its results:
    Walmart = $0.310/oz 100% chlorine
    Lowe's = $0.268
    Leslie's, = $0.281
    Walmart at $2.50 = $0.250
    Trivia: My pool consumes just over 3 ppm/day or 5.3 oz 100% chlorine/day. So the spread of $0.06/oz (0.31 - 0.25) yields a price swing of about $0.32/day or about <$10.00/month.
    Chas & Cheryl (first-time, third-year pool owners)
    Radiant Metric Oval AGP 16'x32'x52"; Pentair: Clean&Clear 150 Cartridge, OptiFlo 1.5 Hp 2-spd, and 320C Feeder (all mounted below water level); Taylor K-2006 & SpeedStir; Maytronics Dolphin E10 (aka Einstein)
    installation pics (2015-2016)
    Jun 2015
    Glendale, AZ
    156
    I am paying $3.59 per 128 oz gal. of HASA 12.5%, which is always fresh and stronger 14% estimate based on use & Pool Math
    I purchase a 4/Case at a local pool store 5 minutes from house, easy in easy out...round trip about 10-15 minutes, so I am happy to do so and maybe pay a bit more and never a worry.
    Valley of the Sun, Arizona.....10k gunite/pebble (Re-surface March 2015) w/in floor Caretaker 99 cleaning heads -- Pentair FNS 60 DE filter -- Pentair IntelliFlo Variable Speed for pool -- Pentair Wisperflo 1 HP for boulder waterfall...Taylor K-2006 & Taylor K-2006C kits
    Jul 2016
    Carlsbad, CA
    29
    The bleach i'm getting at my local Leslies recently says it is 10%, but it's not a Leslies brand. They charge $8.99 for 2 gallons.
    A while ago I got some 10% pool bleach (different brand) at Home Depot for less money, and used it right away, and found it was very weak. I put in enough to add 2 ppm of FC, and a couple hours later there was no change. They store the 2-pack boxes of chlorine in their outside area in a spot where it gets full sun all afternoon. I don't know how old it was when I bought it, but I recently learned that there is a 5 digit code stamped on the boxes of chlorine bottles. The first 2 digits are the year it was produced and the next three digits are the day of the year. Next time I go to HD, I will look at the boxes to see how old they are (out of curiosity), but I won't buy them as long as they are stored in the sun. The bottles I bought at Leslies recently were only 32 days old.
    16,000 gallon outdoor in-ground 16'x32' plaster pool (built 2002); Pentair Intelliflo VF pump; Jandy Cartridge filter;Rainbow in-line chlorinator (used only when I am away); Hayward 2 wheel suction-side pool cleaner; LARS gas heater, Taylor K-2006 FAS-DPD test kit
    Nov 2015
    San Diego, CA
    25
    Quote Originally Posted by RGS View Post
    That's the particular one that I am talking about. They are locally distributed out of El Cajon. If I'm not mistaken it's actually 12.5%. If it's 10 you're better off cruising to Walmart in Encinitas or Oceanside.
    Quote Originally Posted by oldguy70 View Post
    If I could find hasa locally...that would be my preferred buy.
