Page 1 of 3 123 LastLast
Results 1 to 20 of 42
Thread: No FC reading
    snagot923's Avatar
    Jul 2016
    Chester, CT
    15
    Angry No FC reading
    Hello! Just got this pool and I already want to drain it. Water was slightly cloudy....ph was reading 7.4 but no FC. Pool lady said I needed stabilizer. Added what she recommended for stabilizer and the pool proceeded to turn green...like pea soup. Brought water back....was told I had phosphates and needed to clear them up now. Stabilizer level was ok. Add phosphate remover...nothing....still green. So then I read up on shocking. Poured 2 gallons of bleach in the pool. Low and behold the water turned back to blue but was really cloudy...looks like blue milk. FC level was between 1 and 2. Next day looked at the pool...starting to get a green tinge again...tested ph....abt 7.6.....FC level nothing! CYA level between 90 and 100...i have an hts kit....ordering the better one.So I am thinking I have borderline too much stabilizer and need to add bleach daily but not sure how much. I am also thinking I need to get a clarifier to clear the water up. Help please. I'm so frustrated. Oh and this pool has no skimmer...just pump in and out valve. The intake has a small filter screen over it.
    Intex 15x48 above ground pool, vinyl with metal frame
    Krystal Clear filter pump model633T..2500 gal/hr
    Approx 4600 gallons
    Manual pool vacuum
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: No FC reading
    Welcome to TFP!
    Skip the phosfree, floc, clarifier. How much CYA did you add? Any idea how many PPM is in the pool? You need to know what your CYA level is to know how much chlorine you need, FC/CYA Chart.
    PoolMath will tell you how much bleach to add. There is a link at the top of the page. Keep FC at 10 ppm until you know how much CYA is in the pool.
    This is how we kill algae, SLAM
    This is how we take care of pools
    ABCs of Pool Water Chemistry
    Pool School - Getting Started
    snagot923's Avatar
    Jul 2016
    Chester, CT
    15
    Re: No FC reading
    I added 5lbs of the granular stabilizer.
    And I just notice my test kit measures Cl Br level not FC....but it recommends that it is between 1 to 4ppm....so mine is showing nothing
    Approx 4600 gallons
    Manual pool vacuum
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,237
    Re: No FC reading
    Welcome to TFP! Which State is Chester in? Good to have you here
    You mentioned the option of draining, so that would include the cost of a water exchange and scrubbing the pool. The scrubbing is harder work than testing and adding bleach. Some people get there quicker that way, for example 2-4 days elapsed time. If you pay $10 per thousand gallons, that's $50 plus around $30 for chems.
    As pooldv explained, it can be cleared up without ditching the water in a five to ten days of steady chlorine at shock level (we call it SLAM). Just depends on what you find easier / cheaper IMO. To SLAM you need one day of multiple additions when you can be near the pool a good portion of the day, then be able to top up the chlorine at least three times a day (four times is better), and be able to brush the pool a couple of times a day. You can probably clean it up with a partial drain (say $20) and $40-60 worth of bleach, then maybe another $20 to touch up the other chems.
    Either way, move fast and order a proper test kit if you can swing it... TFTestkits.net
    If you're going to keep the water, buy the XL option with the TFTestKits TF100 kit
    The HTH style kit can only handle a re-start, and we have a procedure for that: Pool School - Guide for Seasonal/Temporary Pools
    Ignore bromine (BR). And don't put any bromine in your pool. The test just senses both chlorine and bromine. There won't be any unless you added it. Where your test says Cl, it is the very same as what we call FC.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    DFW, TX
    24,485
    Re: No FC reading
    The OTO, yellow test, measures TC, total chlorine, which is FC + CC.
    snagot923's Avatar
    Jul 2016
    Chester, CT
    15
    Re: No FC reading
    FC is definitely 0...got the cheap strips. CYA is 100...i am SO MAD with the pool store. Test kit is on its way....slam says i need to get FC to 39....no way to measure that yet...any way I can start the process before I get this test kit....this is depressing me
    Approx 4600 gallons
    Manual pool vacuum
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,524
    Re: No FC reading
    I would add a jug (128 Oz) of 8.25% bleach right away, then another half jug per day until your test kit arrives.
    Don't be surprised if you measure FC with your OTO test and it's orange. This will be expected.
    You should start to see some improvement pretty quickly.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    DFW, TX
    24,485
    Re: No FC reading
    Just fyi that CYA could be much higher than 100. That is the top end of the test. We've seen people with pool store and test strip results of 100 actually have CYA of 200, 300 or more.
    The FAS/DPD chlorine test measures FC up to 50 ppm.
    snagot923's Avatar
    Jul 2016
    Chester, CT
    15
    Re: No FC reading
    Great so you are saying i could be in even worse shape?
    Approx 4600 gallons
    Manual pool vacuum
    snagot923's Avatar
    Jul 2016
    Chester, CT
    15
    Re: No FC reading
    Pool is still looking like blue milk..ahhhhhh..
    Approx 4600 gallons
    Manual pool vacuum
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,524
    Re: No FC reading
    I assume you have a cartridge filter. Have you cleaned or replaced it lately? Once the green turns back to blue, it's just a matter of filtering out the dead algae.
    Pentair IC40 SWG
    snagot923's Avatar
    Jul 2016
    Chester, CT
    15
    Re: No FC reading
    Just replaced yesterday....will clean it out now.
    Approx 4600 gallons
    Manual pool vacuum
    snagot923's Avatar
    Jul 2016
    Chester, CT
    15
    Re: No FC reading
    Ok...got a water test done at the pool store
    FC 11.49ppm
    TC 11.97ppm
    CC 0.48ppm
    pH 7.9
    Hardness 160ppm
    Alkalinity 114ppm
    CYA 149ppm
    Phosphates 38ppb
    Copper 0
    Iron 0.2
    Pool still looks like blue milk...cannot see bottom...any thoughts appreciated
    Approx 4600 gallons
    Manual pool vacuum
    DFW, TX
    24,485
    Re: No FC reading
    Your CYA needs to be between 30 and 40. Drain the pool to lower it.
    FC is set based on CYA and the FC/CYA Chart. For the pool to be safe and properly sanitized FC MUST be maintained above minimum at all timew. When FC drops below minimum bacteria, viruses and pathogens are not effectively killed and risk of person to person disease transmission is increased.
    To kill algae we follow this process, SLAM
    Read in Pool School to learn more about maintaining your pool.
    Start here, SLAM
    And here, Pool School - Getting Started
    snagot923's Avatar
    Jul 2016
    Chester, CT
    15
    Re: No FC reading
    Drain the entire pool?
    Approx 4600 gallons
    Manual pool vacuum
    DFW, TX
    24,485
    Re: No FC reading
    No, drain it enough to lower the CYA to 40.
    needsajet's Avatar
    Jan 2016
    4,237
    Re: No FC reading
    We don't trust pool store numbers, but if you decide to trust them, then drain it by 3/4, refill, and hopefully CYA is around 40.
    Good luck with everything
    snagot923's Avatar
    Jul 2016
    Chester, CT
    15
    Re: No FC reading
    Honestly I have no idea who to trust...some have said as long as i keep my fc level higher (following the CYA Chart) then I am ok. I am so confused....what was supposwd to be a happy fun thing for the summer has turned into somewhat of a nightmare....
    Approx 4600 gallons
    Manual pool vacuum
    needsajet's Avatar
    Jan 2016
    4,237
    Re: No FC reading
    That will work if you SLAM to get rid of the algae, then maintain commensurate FC, as you mention. To do that you'll use a known CYA level from doing your own testing. Chances are you will have to drain a fair bit of water to achieve a manageable CYA level. And then do the SLAM, followed by maintaining the correct FC level for the new CYA level.
    Or you can drain, scrub it out, refill, and start over, adding a known amount of CYA to achieve a known level.
    Which part are you struggling to trust?
  20. Back To Top    #20
    snagot923's Avatar
    Jul 2016
    Chester, CT
    15
    Re: No FC reading
    I guess I am just upset that the pool store would say my CYA level was low and were actually the ones that created this mess. We are also in the midst of a drought and have well water...i am not sure where to drain the pool water to without it affecting someone's well. In your opinion what is the highest CYA level that is manageable
    Approx 4600 gallons
    Manual pool vacuum
