Thread: Installation of SWG before the heater
    I am in process of installing new SWG. If I install after the filter and before the heater it will be a 30 minute job. The piping that comes out of the heater only runs about 6 inches before hitting valves and will take major planning and work to re-plumb to accept SWG.
    What will happen if I put this in before the heater? Living in Houston I only use the heater for maybe 10 hours a year.
    I appreciate any advise.
    12' x 24' x 4.5' AG oval (8800 gal.)
    Sta-Rite 200 BP Sand Filter
    Hayward 1 1/2 HP Pump
    Aqua-Trol SWG
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Installation of SWG before the heater
    The SWG should always be installed after the heater. The risk of corrosion to the heater is too great otherwise.
    Jul 2007
    Brisbane, Australia
    874
    Quote Originally Posted by allshotup
    your heater core will corrode quicker than normal, regardless of how much you use your heater
    the ideal installation is when SWG and heater run in parallel
    the next best is SWG after the heater and preferably at some distance from it
    installing it before the heater is a big NO NO, and should be avoided unless absolutely necessary (or unless your heater has titanium core)
    Not the answer I was looking but I am sure you are correct. I will go to plan B.
    Thanks
    Aqua-Trol SWG
