Results 1 to 7 of 7
Thread: aeration from water source other than pool?
    Oct 2015
    DFW, TX
    176
    I've seen several DIY versions of those fountain/aerators that attach to one of the pool returns but was wondering if you'd get a similar effect by hooking something up to a sprinkler system zone running along the backside of the pool? I assume that would add some additional water chemistry concerns since it would be introducing tap/sprinkler water into the pool but is there any added benefit for aerating water from the pool and introducing that back into the water vs aerating water from a nearby sprinkler line and directing that into the pool? from a ease-of-use perspective it might be easier for me to construct something from PVC and leave it attached to a dedicated sprinkler system zone behind the raised beam and run that overnight vs attaching 1-2 PVC fountains to a return and having to connect/disconnect them (however trivial that task might be) on a nightly/daily basis when we're using the pool and wanting the PVC fountains up and out of the way when actively swimming. aside from my laziness, any reason why the two approaches would yield drastically different results?
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    Re: aeration from water source other than pool?
    Well, if you are using tap water the PH could be off enough to not have any gain in aerating. When using the pool water you are dropping the PH of it by aerating the same water continuously, not new water. Can you T your return with a shutoff so you can easily control the fountain instead? Mine is T'd to run water through a pair of solar panels.
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
    30,427
    Aeration raises Ph, it does not lower it.
    mas985's Avatar
    Pleasanton, CA
    11,741
    You didn't say what you were trying to accomplish, raise PH or lower pool temperatures. Aeration does both.
    But assuming you are trying to raise PH:
    For raising PH, the benefit of using the pool water vs added water is that the water that is in the air, is also releasing CO2 where as the water your adding probably isn't. Also, is the water you are adding high in TA and PH like mine? That would be self defeating.
    The most convenient form of aeration is natural aeration. You don't have to do anything. Of course it is the slowest method but what is the hurry? If you have chronically high TA as I do, an acid feeder may be a better approach. You use the same amount of acid either way.
    Mark
    Oct 2015
    DFW, TX
    176
    sorry. should have been clearer. goal is to lower water temp overnight here in TX.
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    Yup, flipped...oops.
    Mike
    mas985's Avatar
    Pleasanton, CA
    11,741
    Quote Originally Posted by darin.brown View Post
    In that case, using the sprinkler would work fine and might even cool it faster push since evaporation is going to be increased, you are automatically filling the pool too.
    Mark
