Thread: Reducer
    Jul 2016
    Hurley, NY
    1
    Reducer
    My old pump and filter were for an above ground pool and I have an I ground, so I decided to upgrade to a bigger pump and filter. The only issue I have is the new system has 2" fittings and my old system was plumbed for 1-1/2". My question is, can I use a reducer to go from 2" to 1-1/2"?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Reducer
    Welcome to TFP!
    Many times the adapter that connects to the pump will fit either 1.5" or 2" plumbing. If 2" plumbing, the pipe will slide outside the adapter. With 1.5" plumbing, the pipe will slide inside the adapter. Can you post a link to the pump you're trying to install? The same goes (sometimes) for adapters on the multiport valve on the filter.
    Isolated Spa - 345 Gallons
