Thread: Hayward s103t filter wont turn on
    Jul 2016
    Warren
    1
    Hello my filter and everything was running fine i turned it off to back wash it and put the dile to the back wash setting when i went to turn it on the filter made a loud humming noise and wouldnt back wash or turn on after that...what does that mean what can i do? The filter isnt on at all...this is for a inground pool
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Hayward s103t filter wont turn on
    Welcome to TFP!
    After the pump stopped working, did you check to see if it had tripped to circuit breaker or a GFCI associated with the pump? Will the pump turn on and prime if you put the multiport valve back to Filter?
    Isolated Spa - 345 Gallons
    May 2012
    Montville NJ
    545
    How long did you leave it making a humming noise
    First check to make sure you have power at the outlet (or that there is power to the feed, if your pump is hard wired)
    Next, check to make sure that a on-pump circuit breaker did to trip.
    Once you have done that, check to see if the pump is seized (can you spin it manually)
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
