Results 1 to 7 of 7
Thread: First time pool owner and my levels are all messed up
    Jul 2016
    Rome, New York
    3
    Hi everyone,
    I'm Tiffani and I live in upstate New York and I just bought a pool for my kids two weeks ago and my levels are all messed up, and i'm trying to figure out how to balance them. I'm hoping to learn a lot on the site.
    7,600 gal. above ground pool, easy set up Coleman 18 FT x 48 inch power steel frame, PVC and triple-layer polyester. 2,800 GPH Intex sand filter pump (.75 HP)-Being delivered tomorrow
    Ideal Values: PH: 7.4-7.6, TA: 80-150, CYA: 30-50 ppm, TC: 1-4 ppm, Free Chlorine: 2-4 ppm, Chlorine compound: 0, Algae: none visible, CH: 200-400 ppm
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Re: First time pool owner trying to figure out how to maintain levels
    Hello Tiffany, welcome. You will learn a lot, most of which is a good thing
    Can you post those messed up levels? What test kit are you using?
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    Jul 2016
    Rome, New York
    3
    My family and I just purchased our first pool and got the water delivered 3 weeks ago and my levels are all off, I have been trying to adjust levels but it doesn't seem to be working. I figured maybe it was because I was using a 1500GPH Flowclear pump and it wasn't moving the water fast enough. I have purchased a 2,800GPH Intex sand filter pump and it is being delivered tomorrow. I'd like to start getting my levels adjusted but I don't know if I should start with specific chemical first and what order I should do them in. Any help would be greatly appreciated. I have been using Clorox test strips and Clorox products. Below are my current levels.
    FC: 0 ppm
    TA: 180
    PH: 6.8
    TC: 0 ppm
    CH: 500
    CYA: 0 ppm
    Jul 2016
    Rome, New York
    3
    Thanks, I will be glad to understand all of this pool stuff. I am using Clorox test strips and I have all of the Clorox chemicals. Below are my current test results.
    FC: 0 ppm
    TA: 180
    PH: 6.8
    TC: 0 ppm
    CH: 500
    CYA: 0 ppm
    May 2014
    Lewisberry, PA
    93
    Re: First time pool owner and my levels are all messed up
    Hi Tiffany, welcome to TFP! Before you get started did you read all the articles in Pool School? How about basics in water chemistry? It sounds daunting but it is really easy and will get you up to speed on what we will be giving you advice on.
    16,000 gallon Oval Vinyl Liner Pool (new liner 2014)
    Custom built in 1999 to be half in-ground and half out (sloped yard) vermiculite bottom, laser sighted to Florida Room and Deck
    Purex Triton Model cc100 Cartridge Filter, 100 gpm flow rate, Penfair 1HP Pump
    TF-100 Test Kit
    May 2015
    Land O Lakes, FL
    527
    Pool School is where to start. Here is a basic starting steps.
    What kind of test kit do you have?
    1. Add Bleach using Pool Math to get it 4 ppm of FC. 4 is the target level for a CYA of 30 (see step 2).
    2. Add enough CYA (stabilizer) using Pool Math to get it to 30 ppm. Hang it in front of the return in a sock or put it in a sock in your skimmer. Squeeze it every once in a while to help it dissolve. It will take at least 2 days but maybe 3 or 4 to dissolve and show up in the CYA test.
    3. Adjust your PH to 7.5 using Pool Math.
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    Nov 2015
    San Diego, CA
    25
    Quote Originally Posted by mgmoore7 View Post
    Tiff,
    When you do step 2 of the above, make sure you do a little less than what is called for. It is always best to follow the "less is more" motto for CYA. Don't ask me how I know. Thank goodness for splash out.
    Chris
