Results 1 to 9 of 9
Thread: Spa draining when pump off
    Jun 2016
    Austin, TX
    334
    My spillover spa is draining to just above the returns each night when the pump is off. Here is a pic of the return side:
    There is the main neverlube valve, then 2 check valves. Not sure why there are 2? Can anyone explain my setup. I am a new pool owner but am very handy. Can anyone explain how to check these for leaks. How do you check these without water pouring all over the place?
    The valve actuator on this side is not working, I will replace that this weekend. Could that be the problem? Or do you think it is the check valves? If so, which one?
    Thanks for the help!
    13k Gallon IG Pebble w/ attached Spa, AquaRite T-Cell-15 SWG, Hayward DE6020 Filter, Hayward 2 HP Pump, Hayward 400k Heater, TF-100 Kit, Pool Logger
    Apr 2015
    tucson, arizona
    1,139
    Re: Spa draining when pump off
    Looks like the builder Tee'd the pool return into the spa, the check valve on the bottom is the one that would prevent water siphoning back to pool. In the picture you have your pool return closed is this normal for you.
    Jun 2016
    Austin, TX
    334
    That position is Spa return closed. Correct? Wait I'm confused now.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Yes, that position is spa returns closed. +1 to working on the check valve.
    Jun 2016
    Austin, TX
    334
    There are 2 check valves. Which one should I try first? The one on the vertical pipe to the right in the pic or the one in the horizontal T facing up? When I remove the valve cover with the pump off will it just gush water or will one or the other check valve prevent that?
    Feb 2015
    Chandler AZ
    938
    If the spa is draining down when the valves are set as in the picture, I'd look at the horizontal check valve first.
    Open the blue pool return valve first. You shouldn't get too much water when opening the check valve that way - the filter may drain down, but will hopefully flow toward the pool returns.
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
    Jun 2016
    Austin, TX
    334
    OK thanks. I know it doesn't look like it but that blue pool return valve is mostly open. They are installed opposite from what you would think. On the suction side, they are vertical when they are open, but on the return side they go horizontal when they are open.
    Feb 2015
    Chandler AZ
    938
    Hmm, never seen that with those type valves - but I learn something new everyday.
    You said the spa drains down to just above the return jets. Is the level it drains down to about equal in height to the horizontal pipe? If so, that would also lead me to look at the horizontal check valve first.
    Oh, and the spa might drain down when you pull either check valve - and flow out of the housing at that point.
    Gene
    Jun 2016
    Austin, TX
    334
    For future reference. That check valve was it. Spa no longer drains! Thank you all. Here is a pic of the new vs old check valve. Old on the right:
