Thread: Check out my numbers.. Replace T15?
    Jul 2016
    wesley chapel
    3
    The pool developed some green spots on the bottom and after the problems I've been having with the cell lately I figured it may have died. Took the water to a local P-a-P pool store to have it tested since I do not own a home test kit yet. Pool is guessed at 11,000 gallons by the measurements taken
    Water results as of yesterday
    Salt-3800
    FC- 0
    pH- 7.8- added 2 cups of acid
    TA- 120
    CH- 150- added 8 pounds after this test
    CYA- 85
    Pool temp is at 85F and is gunite on fiberglass... I think
    The Aqua rite gives me the following
    0 salinity
    89 temp
    31.6 voltage
    0 current
    84P output
    -0 salinity instant
    AL-O product
    r1.40 revision
    The cell is 7 years old and I think you may agree its officially dead.
    I found a couple different threads on here talking about different cells but everyone in the threads had larger pools than mine. I'm wondering at 11,000 gallons if I can get away with a smaller cell or a off brand that some are going for.
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,230
    Re: Check out my numbers.. Replace T15?
    Stick with the T-15 brand name cell, IMO. You can always turn it down and economics are better on larger cells. You should get a lot of years out of it if the water is well balanced.
    If you're only going to be there a year or two, save the money and buy generic, but don't go small. Just my 2 cents.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Software revision 1.40 can only use a T-15 cell (possibly a T-5 if the board has a jumper for selecting a T-5). Stick with a T-15.
    The above numbers were probably in the off part of the cycle. R 1.40 has a 2 hour cycle time. At 84% the cell will be working for 101 minutes and then off for 19 minutes, then it reverses polarity and a new cycle begins.
    You need to check the numbers while generating. Try moving the switch to off, turn the percent to 100, wait about a minute or so and then move the switch to auto. Wait 1 minute and then check the diagnostic numbers.
    Support the site
    Jul 2016
    wesley chapel
    3
    Quote Originally Posted by JamesW View Post
    I believe this was during a generating cycle. I produced these numbers from the diagnostics while on the phone with gold line. They had me turn the switch to off and then back to auto and pulled the numbers you see above.
    Has anyone here tried the generic t15 from ebay? it looks like a direct copy of the original t15 without a label. http://www.ebay.com/itm/Hayward-T-Ce...8AAOSwe-FU2RuO
    Try one more time. When you turn it on, go right to instant salt to see what happens.
    Make sure that the cell is securely plugged in and check for scaling in the cell.
    Support the site
